Old March 27, 2010, 03:54 PM
geokilla's Avatar
Default Updated: My CPU Is Making Noise
My CPU is Making Noise?!? - [H]ard|Forum
My situation is similar to the above thread here. For some reason, my sister's computer, most likely the CPU, makes some weird noise when under load, in the BIOS, or anything like that. As the [H] thread said, it's also possible that it's caused by said coils, but I got no idea what coils they're talking about. Is there anyway to stop this? It's very annoying, though it is a good way to tell if the computer is folding or not without having to turn on the monitor to check. The noise is getting louder as well, and has existed since day 1.
System specs are:
ASUS M2N-E (PoS)
AMD Athlon 64 X2 3800+ @ 2.65Ghz
OCZ + Patriot 4GB DDR2 RAM
ATI X850XT
OCZ StealthXStream 500W
Updated: Going to sell the ASUS M2N-E. About how much is it worth? I'm thinking maybe $20?
Old March 27, 2010, 04:14 PM
its the mobo for sure, sometimes the cards can fizz as well.
Old March 27, 2010, 04:22 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Yeah its the mobo. I had the M2N-Deluxe. Biggest POS I ever owned. Most likely its the coils. There are some things to do to fix the noise (like hot glueing the copper coils) but the easiest fix I found....was replace the mobo.
Old March 27, 2010, 04:40 PM
geokilla's Avatar
Motherboard... I feared that as it's an AM2 socket, and those motherboards are pretty hard to find now for cheap.
NCIX.com - Buy Gigabyte GA-MA770-UD3 ATX AM2+/AM3 AMD770 PCI-E16 2PCI SATA2 RAID 1394 HD Sound GBLAN Motherboard - GA-MA770-UD3 In Canada.
Seems to be the best I can get if I switch only the motherboard. But do we really want to do that?
Old March 27, 2010, 04:41 PM
wasnt am2+ backwards compatible? but think twice before the 'upgrade'
Old March 27, 2010, 04:49 PM
AkG's Avatar
AkG AkG is offline
Ok, if you ARE going to upgrade (and thus no harm if things go bad) the first thing I would do is backup all your data. THEN stress the hell out of your system. Use prime95 or other similar tools. Pop the cover off your side pannel and listen to where the noise is coming from. Most likely it is a big copper coil vibrating. Get Ye old hot glue gun out. Let the hot glue gun warm up. Power down the system and apply a small amount of glue on the copper of the offending coil. Let it cool and harden. Reboot. Stress the system. See if the noise is gone. If it is. Start saving up for a new mobo and or sys as this is a short to mid term solution only and NOT a permanent fix (it should last a long while...but you never know).
Old March 27, 2010, 04:53 PM
geokilla's Avatar
No glue gun so that requires me going to the dollar star haha. I'll either leave it as is or get another motherboard when we get the case.
The side panel was off earlier, and when I put my ear to it during it was folding, there was definitely a sound in the CPU area. I'm not sure which coil it'd be coming from as I didn't know about this till now. I will however take the temporary fix into consideration. Thanks!
AM2+ is backwards compatible, but a lot of deals are for AM3 now. I'm looking at AM2 mobos with integrated graphics right now. My sister doesn't need that X850XT. The X850XT is un-needed heat and power hog. If only there were ATX motherboards that also have integrated graphics. So far, I can't seem to find any.
Old March 27, 2010, 05:10 PM
there are. look into giga boards. am2+ plenty. bout 100 bucks tax in. but be sure this is the way you want to go before changing your mind in 1 month or so
Old March 27, 2010, 05:31 PM
Oversized Rooster's Avatar
You can get the Gigabyte GA-MA785G-UD3H motherboard. It's an AM2+ socket and can run AM3 CPUs plus it has integrated graphics roughly equivalent to a Radeon 3450 video card.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old March 27, 2010, 06:01 PM
its actually called a 4200. can play 1080p nicely :)
Making a game. nick_black O/S's, Drivers & General Software 15 February 20, 2010 06:48 PM
Fans mounted on radgrill making wierd noise? chouchou Air Cooling 3 July 23, 2009 10:26 PM
gtx 275 is making noise... (not the fan) lexmark1 Video Cards 19 May 20, 2009 04:22 AM
Auzentech X-fi prelude making noise elec999 Audio 1 February 1, 2009 09:09 PM
Samsung Spinpoint F1 1TB Making Lots of Noise arekieh Troubleshooting 3 November 27, 2008 08:16 PM
