Old March 27, 2010, 07:38 PM
jcmaz's Avatar
In the cheap section would be the Asus M2A VM w/ the 690G chipset...
-Plato
Old March 27, 2010, 07:56 PM
Oversized Rooster's Avatar
True, but the M2A-VM:
1) Does not support AM3 CPUs.
2) Has very weak integrated graphics which cannot play 1080p video.
3) Cannot run dual PCI-E video cards in Crossfire or not.
4) Does not use solid capacitors.
5) Has only 4 SATA ports.
6) Does not have HDMI out (except for the HDMI version of that mobo).
7) Does not have dual chip BIOS redundancy.
8) Only saves you about $20 compared to the MA785G-UD3H even if you find one on sale.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old March 27, 2010, 08:03 PM
jcmaz's Avatar
err... i mean't used
-Plato
Old March 27, 2010, 09:09 PM
geokilla's Avatar
Hopes of getting a new motherboard got shot. As soon as my mom heard the word "buy motherboard" she gave me the sour face. My sister will have to convince her if she wants the noise to go away.
Old March 27, 2010, 09:15 PM
tell her it may cause cancer
Old March 31, 2010, 08:26 PM
geokilla's Avatar
Here's something that I thought about. Dunno if it'll work well or not though.
Canada Computers - Motherboards > Socket AM2+ : Gigabyte GA-MA785GM-US2H Socket AM2+ AMD 785G + SB710 Chipset ATI Radeon HD 4200 Graphics with HDMI/DVI/VGA DDR2 1200(O.C.)/1066/800/667Mhz 5x SATA 1x eSATA 3Gb/s 7.1-Ch HD Audio GigaLan IEEE1394 PCI-Ex
NCIX.com - Buy Gigabyte GA-MA785GT-UD3H AMD785G ATX AM3 2PCI-E DDR3 Video Sound GLAN CrossFireX HDMI Motherboard - GA-MA785GT-UD3H In Canada.
Buy one of the above. Sell my PoS M2N-E and X850XT. Therefore, the noise is gone, and I get to save a bit of electricity as well as probably get to push a few more Mhz out of the RAM and AMD X2 3800+. The only downside is that 6h4 US2H motherboard is micro-ATX. Would it have an effect on anything? I got a Creative Audigy 2 soundcard and PCI wireless adapter. Though I can use a USB wireless adapter instead.
P.S. I'd be mounting my current OCZ Vendetta 2 on that motherboard. Or it'd be on my current M2N-E if I don't upgrade the motherboard. We're getting a new computer case for sure though as hers is falling apart.
Old April 1, 2010, 02:16 PM
geokilla's Avatar
bump !
Old April 1, 2010, 03:38 PM
jcmaz's Avatar
Second option because you can fold on the second slot :) and its AM3
-Plato
  #19 (permalink)
Old April 1, 2010, 03:55 PM
sswilson's Avatar
If you're still interested in finding out what particular component is "whining", apply pressure to the individual components with the erasure end of a pencil while it's under load. If you can isolate the discrete component you might be able to slap epoxy on it to deaden the noise.
  #20 (permalink)
Old April 1, 2010, 04:22 PM
geokilla's Avatar
Crap... just saw the AM3. I need it to be AM2+
@sswilson. Thanks for the suggestion. According to google, epoxy = glue? So I just like glue the component together or something?
Making a game. nick_black O/S's, Drivers & General Software 15 February 20, 2010 06:48 PM
Fans mounted on radgrill making wierd noise? chouchou Air Cooling 3 July 23, 2009 10:26 PM
gtx 275 is making noise... (not the fan) lexmark1 Video Cards 19 May 20, 2009 04:22 AM
Auzentech X-fi prelude making noise elec999 Audio 1 February 1, 2009 09:09 PM
Samsung Spinpoint F1 1TB Making Lots of Noise arekieh Troubleshooting 3 November 27, 2008 08:16 PM
