Old October 24, 2007, 06:28 AM
chibi_man's Avatar
Default Whats a better deal... Athlon vs. Opty
Been in huge debate over what processor to get. For the longest time it's been opty ALL THE WAY... however, A buddy of mine found this and it's now making me think again.
NOTE* S939
AMD Athlon 64 X2 4400+ Processor - 2.20GHz, 2MB Cache, 1000MHz (2000 MTs) FSB, Toledo, Dual-Core, Retail, Socket 939, ADV4400CDBOX, Processor in Canada at TigerDirect.ca
From what I know.. thats a $350 to $400 processor 2 or so years ago.
Now if I were to buy an opty 165
Premier Computer Canada
Or even one higher then that. Whats the better deal in performance and reliability perspective. Price is undeniable, It's a killer deal.
So is opty worth the extra cash?
_____________________________________
If you can't beat it...
Old October 24, 2007, 07:37 AM
Amon's Avatar
In this case, it would just be better to use the Athlon X2. Opterons are usually only a consideration when they are at parity with the Athlon sibling.
Old October 24, 2007, 08:16 AM
cdn_Madrach's Avatar
The opty 165 oc's well....2.6- 2.8 np usually. But I don't know how well the x2s compare. I would pick the opty over the 4400x2 just my 2 cents.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old October 24, 2007, 08:55 AM
chibi_man's Avatar
for $100 I can get a really nice processor with stock 2.2.. or spend $180 and get the opty 175 at 2.2...
like GAH... from what I can tell.. there isn't much difference other then the price. This is a tougher decision then it looks.
Old October 25, 2007, 05:32 PM
Cptn Vortex's Avatar
Just get the cheaper one, buy yourself some beers and a better heatsink, and you're good to go!
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old October 25, 2007, 05:59 PM
sswilson's Avatar
The 165 seemed to be the way to go when I was looking at them. IIRC, everthing after that was hitting pretty well the same OC wall no matter where stock speeds started at.
It's been a while though so my memory might not be as good as it should be.
Old October 25, 2007, 06:03 PM
I've got a Opteron 170 which runs happily at 2.95GHZ, which is great, but considering you are keeping an old system alive, may as well go for the best cheapest option until your next purchase, which should be soon, if you plan on being able to play some new titles, Crysis rings a bell, that will need more than a lowly sub 3.0GHZ dual core can offer.
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
Old October 25, 2007, 06:34 PM
Killswitch's Avatar
Get the 4400+. It'll overclock just as well, and you'll like the possibilities from the higher multiplier.
Opty 185 Freezing in games mrbonerman Troubleshooting 4 February 5, 2008 01:59 PM
Whats the big deal about blueray? Shadowmeph HTPC Systems & Software 7 January 11, 2008 01:08 PM
AMD Opty 180 chibi_man CPU's and Motherboards 11 November 11, 2007 12:35 PM
whats this mean ? Jim CPU's and Motherboards 8 July 25, 2007 05:39 AM
Whats your opinion on this? ragenrok RAM 11 April 25, 2007 04:30 AM
