Old March 22, 2010, 02:03 PM
Wurmer's Avatar
Default Unlocked BE555 temperature
OK here is,
I've unlocked my BE 555 to 4 core and tested it with prime for 18 hours everything seems to be fine but it's seems that getting temperature measurements is a bit of a problem. PC Probe seems to work but it's probably not the best program to do so. I have tried using HW Monitor but it gives me 0 C for all cores. Anyone having this problem ? and if so what did you do to circumvent that ?
Old March 22, 2010, 02:10 PM
SugarJ's Avatar
Try coretemp: Core Temp
Old March 22, 2010, 02:49 PM
geokilla's Avatar
That's what happens when you unlock. Just go with the CPU Temp in PC Probe and HWMonitor.
Old March 22, 2010, 07:31 PM
Wurmer's Avatar
Well Core temp is not working anymore than HWMonitor.
Old March 22, 2010, 07:34 PM
SugarJ's Avatar
Must have something to do with the unlock, Coretemp works with all Phenoms.
Old March 22, 2010, 07:38 PM
speedfan should also work. works with the 550 unlock
Old March 22, 2010, 07:43 PM
Wurmer's Avatar
True I had forgotten about speed fan, it's just annoying that it need calibration... I might give a spine though.
550 BE unlocked jay51 CPU's and Motherboards 6 December 8, 2009 11:12 AM
X2 550BE Unlocked Caldezar CPU's and Motherboards 9 October 9, 2009 09:13 AM
[WTB] Unlocked HTC G1 Jackquelegs Buy/Sell & Trade 0 September 9, 2009 09:35 PM
Phenom II X2 550BE (UNLOCKED) punk_zappa Overclocking, Tweaking and Benchmarking 75 August 29, 2009 11:45 PM
Where do you guys get your unlocked phones? muse108dc Off Topic 12 February 21, 2009 12:51 AM
