Old October 23, 2007, 10:39 PM
Default Which CPU for this mobo
if i go intel, this is the mobo im going to get, kinda on the fence on weather i should get RAID or not, its like 40 bucks more does it really make that big of a difference? in games and such
EVGA Nforce 680I SLI LGA775 Conroe ATX DDR2 2PCI-E16 2PCI SATA2 Sound GBLAN 1394 Motherboard
and its either
Intel Core 2 Duo E6750 Dual Core Processor LGA775 Conroe 2.66GHZ 1333FSB 4MB Retail - 217$
or
Intel Core 2 Duo E6850 Dual Core Processor LGA775 Conroe 3.0GHZ 1333FSB 4MB Retail - 308$
soo now im just wondering which one i should get. i was thinking i could get the cheaper one and OC to 3ghz, but i could also just OC the 3ghz to 3.4.. lol which do you think has better OC ability, and has better performance/price ratio thanks. and also, for my mother board the "1394" is its maximum BUS speed right? which the cpus have 1333?
im a noob
Old October 24, 2007, 12:04 AM
"1394" is Firewire support.
And for $308, why not a Q6600 instead?
Old October 24, 2007, 01:08 AM
Apollo4g's Avatar
Just get the Q6600 or the E6750 and overclock it.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old October 24, 2007, 01:17 AM
BrothaInFaith's Avatar
get the quad.
it will last longer. quad core support in all new games and programs will more than take care of the clock speed disparity.
dfi bi p35-t2rl|xeon x3210@3.4ghz|evga 8800gts 320mb|2gb mushkin hp2|audigy 2zs|lian-li pcv1200|2005fpw|mx3100|promedia ultra 5.1
Old October 24, 2007, 01:21 AM
if you get the Q6600, make sure you get A1 version of the evga 680i; the cheaper TR revision doesnt support quad core overclocking.
Old October 24, 2007, 02:34 AM
alright, i revised my computer to this
250$, out of the 3 comp stores online i was looking at, this was the only one that specifically told me it was A1
EVGA NF68-A1 SLI Socket 775 nVidia nForce 680i Chipset Dual-Channel DDR2 533/667/800 Support 1066/1333 FSB 8-Channel High Definition Audio 3x PCI-Express Graphic Slots Heatpipe Design
Intel Core 2 Quad Q6600 Quad Core Processor LGA775 Kentsfield 2.40GHZ 1066FSB 8MB Retail Box - 278$$
now im looking for a better heatsink, any suggestions? if it says it fits a LGA775 socket, that means for Quad too right? ive seen some that mention DUO, but not QUAD
also RAM lol, the 680i is a popular mobo im sure some of you can tell me what RAM works good with it
Old October 24, 2007, 06:29 AM
anyone?? lol, no hurry i guess
Old October 24, 2007, 07:56 AM
Fallen Folder
depends how hard you want to oc it ... an AF7 is cheap and will get a G0 stepping q6600 > 3.0 ghz assuming <1.4 VC. There are better ones around for not a lot more but i am not up on the latest models.
I also use TT Big Tyhpoons and Sonic Towers on a lot of my quads but with upgraded/dual fans on most. I bought them for my oc'ed 930D's originally.
If you want to get to 3.5 + you will need water ... at least if you run it 724 smp folding at 100% like i do. There aren't too many workloads that will run a quad at 100% constantly tho.
If you get a B3 stepping, they will need more VC and hence better cooling and still won't oc as high in general as a G0. Try to get a G0 if you can.
Old October 24, 2007, 08:38 AM
now G0 stepping, is the latest types of intel cpus [quads and some duo's] that allow highest ammount of OC right? and VC means Voltage right?
lol i must say that awnser confused me much more than i'd like to admit
Old October 24, 2007, 10:16 AM
Shadowmeph's Avatar
If your not in a hurry (like me building my pc slowely but surely) I would wait for a couple of months I copied and pasted the following from this site bit-tech.net | Intel preps 45nm quad-core for launch
Mainstream editions of Yorkfield will launch sometime in January with a vague January 2nd through 20th listing from Intel.
The 2.83GHz Q9550, 2.66GHz Q9450, and 2.50GHz Q9300 will be priced at $530, $316, and $266 each in 1,000 unit quantities respectively. Like the QX9650, they will also have 12MB of L2 cache but this time will be in the 95W TDP band.
I have heard ( but not sure if it is true) that those processors are supposed to run a little cooler also
Which mobo should I buy? yycraven CPU's and Motherboards 27 January 15, 2008 08:31 PM
Mobo and DVD DSNB Troubleshooting 6 December 27, 2007 07:08 PM
Bad cpu/mobo for o/c? Frustian Troubleshooting 6 November 3, 2007 10:09 PM
new mobo and ram help tony the tiger CPU's and Motherboards 6 September 19, 2007 06:24 PM
Mobo cdn_Madrach HTPC Systems & Software 8 July 6, 2007 05:51 AM
