Originally Posted by siqueirah Simply amazing !
But now I don't know which mobo I should get.
3way Classified or R3E ?
What do you think ? |
It is really close, but what got me to grab the R3E was this...
-SATA 6Gbps that was able to RAID (even if it was only two ports)
-USB 3 ports (no headers tho
-Slot spacing and PCI-E lane assignment. (Have an inverted ATX Murdermod that is in its final stages and moved from the R2E at the last moment when I saw how much better it would all work out with the cards arranged the way I wanted, and running my 5870 running at full 16x PCI-E 2.0) You will see what I mean when it is done.
-How awesome the EK R3E Acetal Fullcover Block looks. Saves me 4 barbs and a whack of tube routing over my R2E Bitspower NB/SB and PWM blocks.
-Wanted to play with ROG Connect
-Hybrid PWM sounded great and seems to run fairly cool. Waiting to get my loops together to really push this board and see what it can do , if even only under water.
