Old October 21, 2007, 08:03 AM
Default Build a new rig
Hello all. New to this forum and gaming computers in general, but want to take the plunge. Here's what I'm thinking about getting:
Intel Core DUO Q6600 2.4
ASUS P5N32-E SLI
320 GB SATA2 Harddrive (x2)
ANTEC Sonata 3 w/500 Watt power supply
Nvidia 8600 GT 256 Pci-x (x2)
I believe the board is 68i. Not sure how this package will work together. Any comments, advice, changes, would be greatly appreciated. Money is an issue so if you see something dumb in this arrangement please post it. Thanks.
Old October 21, 2007, 09:05 AM
magictorch's Avatar
Default just a few comments
I would not buy the 8600Gt. Wait a few weeks for the 8800GT!, the extra $100 will be worth it.
The 500watt PSU may struggle if you start to OC the quad (youll need a good heat-sink for that) and add a decent GPU.
The quads are great but you could get a more recent and highly overclockable core2 for less and free the money up for the GPU, PSU and heatsink.
If the 8800GT is as power efficient as its supposed to be and the 500watt psu is solid you may get away with it on a dualcore. You would see better performance in games than having a quad and a lesser GPU.
Old October 21, 2007, 10:26 AM
JD JD is offline
Definately don't get 8600GTs in SLI. That's a total waste. Even a single 8800GTS would do better. But the 8800GT is coming out very soon so you might as well wait for that.
As for the motherboard, if I was to get a 680i chipset based motherboard, I'd get it from eVGA. They seem to have extremely good support.
You don't seem to mention what RAM your getting either.
Old October 21, 2007, 10:27 AM
Delavan's Avatar
I would forget about the SLIed cheaper cards setup...If you want to SLI, go for dual 8800 GTS 640Mb or GTX or Ultra setup. Anyway, I would, myself, forget about the SLI mobo (save $100 average) and get a 8800 GTS 640Mb or better.
Or like Magictorch mentionned, you could wait for the GT!
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old October 21, 2007, 12:27 PM
Thanks for the replies.
So maybe I'm not totally clear on the SLI vs a single card setup. I thought the 2 cards would out perform the single higher end card. Also want to take into account future upgrades with the quad and the sli.
Old October 21, 2007, 12:28 PM
Oh, I forgot the ram would likely be OCZ 2 Gig DDR 2 1066
Old October 21, 2007, 02:37 PM
Delavan's Avatar
I realize that SLI sounds "sexy" and powerful. The thing is that it doesn't mean "double" the performance. Sometimes you reap the benefits, depending of the game, drivers and all. And no, those 2 cards won't out perform a single High-end card.
For the RAM ,I like Mushkin, there is quite a few people that got DUD OCZ Ram kits...
Anyway, if you want to go SLI, more power to you, but I would buy a 8800 GTX, OC it to Ultra specs, and grab a second GTX later on...
Old October 21, 2007, 03:19 PM
Thanks for the info...
The problem is that dang 8800gtx is so expensive. Maybe the 8800 gt will be a little more affordable when it comes out?
If I SLI two cards, we're talking big bucks
Old October 21, 2007, 03:38 PM
sswilson's Avatar
General rule of thumb is that SLI (or crossfire) isn't going to provide the same (or better) performance than a single higher end card unless those two cards together will end up costing more than the single, and even then the benefits are dubious.
The only folks who really should be running SLI are those who already own one decent card and who can get their hands on another for a good price, or those with way too much money who can afford to buy two of the latest uber card and SLI them together.
Old October 21, 2007, 04:18 PM
Oh and a GTX card won't fit in the Sonata series :) You'll need to go bigger.
My Next Build. BALISTX CPU's and Motherboards 13 October 4, 2007 11:53 AM
First build. l0ck Troubleshooting 15 July 25, 2007 04:24 AM
New build -Yes it's fun... Il Duce CPU's and Motherboards 15 July 8, 2007 07:57 PM
New Build and soon to go buy neurobashing CPU's and Motherboards 10 June 20, 2007 09:23 AM
My first ever build, help me out paolo CPU's and Motherboards 31 June 9, 2007 04:04 AM
