Old March 12, 2010, 01:33 PM
Fudd Rucker's Avatar
Default i7 860 TDP
Had a quick question that I couldnt find an answer on google.
What would the total TDP be on an i7 860 when clocked at 4ghz - 200x 20?
Vcore 1.381v
VTT 1.36v
PLL - 2.00v
PCH - 2.4v
DRAM - 1.66v ( DDR3 1600 - 7-7-7-18 1T)
Id assume other then the PCH which is offchip, that upping all those voltages must bring the TDP through the roof no and would create a great strain on the VRM along the socket?
I know stock the chip is 95w and will spike to 110w with turbo mode running full bore. But I cant seem to find any numbers to indicate would an i7 chip would output for total heat when running Vcore/VTT/DRAM voltages turned up to acheive overclocking.
I couldnt think of something snarky or interesting to put here this time around.
Old March 12, 2010, 04:07 PM
Wi-Fuzzy's Avatar
Acording to an online calculator I found...about 155 watts. Yikes...my 920@ 3.8 ghz is 206...
Old March 13, 2010, 08:21 AM
165-180W assuming a stock voltage of 1.2-1.25V.
Your motherboard's VRM circuitry should be able to handle that without any trouble.
i7 860 or i7 920??? dante1 New Builds 11 December 27, 2009 03:17 PM
I7 - 860???? Recker New Builds 3 December 6, 2009 08:24 PM
I7 860 martin_metal_88 Overclocking, Tweaking and Benchmarking 5 November 6, 2009 10:37 AM
