  #101 (permalink)
Old September 21, 2010, 04:20 PM
rjbarker's Avatar
^^^ Are you also trying to run your RAM at stock speed Bob? I am now playing around testing with "VDroop Disabled" in Bios....now that I know a stable "load voltage" I can work from thier, for 4.11 with VDroop was vcore 1.4125 - 1.355 Load...so without VDroop tried 1.35v - load 1.364v...ran P95 fine for 3 hrs....so now dropped to 1.3375 and test some more.....perhaps it was really hindering my OC'ing with VDroop enabled....not sure how the vTT is affect by VDroop, maybe that dips dramatically as well......fun playing around with it though.....
Yes I''m going to try playing around with QPI once I nail down the lowest possible vCore / vTT at 4.11 "Without VDroop".....gives me a solid "base" to work from, instead of running around in circles for the 1st few days with settings / testing hoping I "luck" out.....I alwats tend to get hasty with my OC'ing when I get a new chip ;)
For 4.3 I'm thinking of trying QPI 160 Mhz 2;10 RAM and x27 Mult.... ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
  #102 (permalink)
Old September 21, 2010, 07:18 PM
kruzn4evr's Avatar
Here's my current numbers under load (just turned on P95 to bring it upto load)
  #103 (permalink)
Old September 21, 2010, 09:05 PM
rjbarker's Avatar
^^^^ A little tough to see, but it looks like 1.364v underload.....I wind up with 1.355v under load for 4.11....I guess my chip is in line with yours....
Here's the results of my Vantage run @ 4.33 Ghz 480's 835 / 1975 -applied about 1.125v (definitly too much as Temps were through the roof on the 480's).....I'm a noob with Overvolting GPU's ....hahahahah..some goofy shvt happening with my GPU's / display after that Vantage run..had to reboot ;)
Moved up a few more at Evga 480 Sli thread ;)
And here is my OC Template for 4.11 Ghz
Mother Board ( EVGA Classified E-759- A1 )
Drivers (9.1.1.1025 )
Bios ( 74 )
CPU( Intel Core i7 980 XE )
CPU Cooler (Air - TRUE Push / Pull w IC7 )
Memory (Dominator 1600 Mhz 6 GB )
PSU ( Corsair AX 1.2 kW )
GPU ( EVGA 480 GTX x 2 Sli - OC’d 1640 / 1925 Mhz)
Drivers ( 260.63 Beta )
Operating System ( Windows 7 x64 )
Frequency Control
CPU Clock Ratio (31)
CPU Host Frequency (Mhz) (133 )
CPU Frequency ( 4.11 GHz )
MCH Strap (1600 Mhz)
CPU Uncore Frequency (Mhz) ( x24 - 3200 Mhz)
CPU Clock Skew (0 ps )
Spread Spectrum (disabled )
PCIE Frequency (Mhz) (100 )
OC Recovery (disabled)
Turbo Performance (
disabled )
Memory Feature
Memory Speed (1600 Mhz )
Memory Control Setting ( 2:12)
Memory Frequency (auto )
Channel Interleave Setting (auto )
Rank Interleave Setting (auto )
Memory Low Gap ( auto)
tCL Setting ( 8)
tRCD Setting (8 )
tRP Setting (
8 )
tRAS Setting (24)
tRFC Setting (88 )
Command Rate (
1T )
Voltage Control
EVGA VDroop Control (
Tested with Vdroop / Tested without Vdroop )
CPU VCore (
1.4125v ) (1.34375v) - both result in 1.355v under full P95 Load
CPU VTT Voltage (
+ 100mv - 1.30v / + 75mv - 1.275v) – Stock 1.2v
CPU PLL VCore (
1.8v) - Auto
**IOH PLL VCore (
1.8v ) - Auto
DIMM Voltage (
1.65v)
DIMM DQ Vref (
+0 )
QPI PLL VCore (
1.1v ) - Auto
IOH VCore (
1.125v ) – for Sli config
IOH/ICH I/O Voltage (
1.5v ) - Auto
**BR04 ( NF200) Voltage (
1.2v ) (only on E-759) - Auto
**VTT PWM Frequency (
250 khz )
**CPU PWM Frequency (
800khz)
**CPU Impedance (
Auto )
**QPI Signal Compensation (
Auto )
ICH VCore (
1.1v )
*PWM Frequency (
default )
CPU Feature
Intel SpeedStep ( disabled)
Turbo Mode Function (disabled )
CxE Function (disabled )
Execute Disable Bit ( disabled)
Virtualization Technology (disabled )
Intel HT Technology (enabled )
Active Processor Cores (all )
QPI Control Settings (enabled )
QPI Link Fast Mode (enabled )
QPI Frequency Selection ( auto)
PnP/PCI PCI Express
Maximum Payload Size (
128 bytes) Auto
Power Management Setup
ACPI Suspend Type (S3 )
HPET Support (enabled )
HPET Mode (32 Bit )
Max Temps / Operating Temps under Full P95 Small FTT Load:
Core 0 – 65C / 63C
Core 1 – 64C / 63C
Core 2– 56C / 55C
Core 3 – 60C / 58C
Core 4 – 66C / 65C
Core 5 – 69C / 67C
* LinX x64 - Max Memory - 25000 Problem Size – 35 Cycles - No errors - 51 G/Flops
Prime 95 Small FTT – 6 Hrs
* With 980X I have consistently found lower Max Temps running LinX Test vs P95 and have also found that passing LinX consistently results in failing P95 (BSOD requiring further bumps in VCore). At this point its fair to say P95 is the better choice for testing 980X OC stability.
For 4.3 I went QPI 160 x 27 - RAM 2:10 for 1600 Mhz
vCore set to 1.4125v without VDroop
vTT +175 - 1.375v
Still very likely not P95 stable though...got me through the PhysX part of Vantage without going kack ;)
MARK 11: 32.530
  #104 (permalink)
Old September 23, 2010, 01:21 PM
Avid6eek's Avatar
The overclocking results are looking good. I expect to have my i7 980x arrive either tomorrow or Monday. I've had the Corsair AX1200 for a few weeks now and it has been great.
I don't fold...I game...5870's FTW.
INTEL core i7 980x Fore sale in EUROPE 1000 L ( HWBOTS.com ) ZZLEE Rumor Mill 8 March 11, 2010 09:26 PM
Comment Thread: A Summer Road Trip with the Intel Core i7 975 EE 3oh6 CPU's and Motherboards 19 June 11, 2009 10:00 AM
Intel Core i7 920, 940 & 965 EE Review Comment Thread MAC CPU's and Motherboards 67 January 27, 2009 07:00 PM
