Old March 4, 2010, 03:10 PM
Default ASUS P7P55D-E Pro AI Tuner in the Bios
Noobie question. Could anybody give me a little advice on this section of the bios for this board? Though I don't want to overclock I set the AI overclock Tuner for XMP as recommended by the tech at G.Skill as this memory is Intel XMP ready. He said this would optimize the memory performance but not over clock it. Further down the list of Bios options is something called OC Tuner. The manual says the default is [Good Performance]. The settings are Good Perf, Better Perf. and Turbo Profile. I didn't change this setting but it was set to Turbo Profile not Good Performance as stated in the manual. I even loaded the defaults to make sure Turbo profile was the default and it was. I have left the bios at these settings and the system seems to be running fine. The manual says to set to Good perf or Better Perf as a stable setting for daily use and choose Turbo Profile as an advanced overclocking setting for special purposes. I haven't loaded much on this machine yet but it seems to be running stable. Should I set this to Better performance or should I leave it until I experience stability issues?
One more thing. How can I tell what the CPU and memory are running at with CPU-Z? Or is there a better way to monitor this after each bios setting?
In CPU-Z my core voltage fluctuates slightly from .856 to .920. Core speed is 3474 MHz but also fluctuates very slightly up and down. Same with the Multiplier X26 to X25. Bus speed is 133.6 and QPI link is 2405.1. Are these values supposed to fluctuate a little and why is the core speed 3.47 when I haven't overclocked anything?
Thanks
Jim
ASUS P7P55D-E Pro - Intel i7 860 - Zalman CNPS 10X Quiet - 4gb G.Skill Ripjaws DDR3 1333 CL7-7-7-21 1.5V - Intel 520 Series 240 GB SSD - WD Caviar Black 1Tb - Corsair TX750W - Sapphire Radeon HD 5770 1 Gb GDDR5 - DVD Drives X2 LG GH24LS50 - Coolermaster CM690 II Advanced - Win 7 Pro 64
Old March 6, 2010, 07:16 AM
Well if nobody has this board and can't comment on my question, could anyone help me with my CPU-Z question?
Thanks
Jim
P7P55D-E Pro & G.SKILL F3-12800CL9D-4GBRL Hopper CPU's and Motherboards 10 February 15, 2010 12:25 PM
i5 750 + ASUS P7P55D EVO Signal2Noise Overclocking, Tweaking and Benchmarking 5 January 25, 2010 09:25 PM
ASUS P7P55D Pro & 8pin EATX12 with cap Logger CPU's and Motherboards 3 January 2, 2010 02:18 PM
Asus P7P55D SATA problems Wolfx25 CPU's and Motherboards 1 December 30, 2009 12:36 PM
PCTV HD Pro Stick HDTV Tuner ?? frosty Peripherals 0 April 13, 2008 05:04 AM
