Old March 3, 2010, 08:57 AM
MarkOne's Avatar
Default core sensor not working
I'm testing a gigabyte ep-45-ud3l with a e7500
the core temp stay at 40'c what ever load test I pass on the system, is it the e7500 who don't have core sensor or it's again a crapy Gigabyte problem.. I flash the bios to the last version .
Old March 3, 2010, 09:00 AM
matsta31's Avatar
seems like a stuck censor. Happened to me a couple of time. It is not mobo related normally but comes from the CPU. Are both censor stuck ?
Sold hardware again.....
Currently using WHS hardware....
Old March 3, 2010, 09:01 AM
shaw
Guest
Posts: n/a
Either:
- both Core sensors are dead
- both Core sensors are stuck, and while testing never went higher than 40C.
Option 1 is a chip defect, you can RMA (I think)
Option 2 is a chip defect, and you cannot RMA it.
OC the chip and push it ever more.
Old March 3, 2010, 09:15 AM
MarkOne's Avatar
I made a test sensor and they both stock.. I google a little bit and it's normal on the e7500 to have this problem... I will put a e8400 on the board to see if it change. but latter my son need the pc
Old March 3, 2010, 09:43 AM
burebista's Avatar
Relax man, stuck sensors on 45nm Intel CPU's are like bread now, very common.
If they move in full-load it's OK, forget about it and enjoy your rig.
If it ain't broke... fix it until it is.
Old March 3, 2010, 10:10 AM
paphman910's Avatar
My cpu have a stuck sensor at 40 C on my sister's Q9550. I ran it for a couple of hours and the temperature did move on the core with 40 C. I posted a thread somewhere on this forum and two members said the cpu is running fine.
What I find odd is the multiplier on the stuck core stays at 8.5 whereas the other cores are 6.0 at idle!
Is it the same with your cpu?
Paphman910
Paphman910:
(PC Power & Cooling Silencer 610) (Asus P5K-E/WiFi-AP) (Xeon E3110) (G.Skill 4GB DDR2-6400 800) (8800GTS 512 MB) (Seagate 500GB) (Pioneer 212D DVD Burner).
Old March 3, 2010, 10:13 AM
MarkOne's Avatar
sorry, I will not relax. and change this CPU .... this is a test bench PC . so I need sensor. I just put a wc block on it...this crap CPU will do in an other place , anyway, my plan was to put the e8400 on it, I put the e7500 to bench test my 5870 with a low end cpu ... and after my bench test with the e8400 , the 5870 will go on my i5-750
Old March 3, 2010, 10:16 AM
You should see the sensors on my q9550.. its a joke.
They are so out of alignment of each other I don't bother.
Don't worry about it as the load temps will still work fine.. its just idle temps are screwy.
Old March 3, 2010, 10:18 AM
MarkOne's Avatar
the load temps do not move at all. I will put my e8400, I know this cpu have good sensor.
Old March 3, 2010, 10:34 AM
What program do you use?
And what is your ambient temp like?
What type of cooling?
Adapters for 1.6x crop sensor DSLR's? oblisk Off Topic 10 January 13, 2010 03:07 PM
Stuck Sensor - What to do? crazyhorsejohnny CPU's and Motherboards 20 May 22, 2009 09:57 AM
Core Temp Sensor issues HalifaxJ Troubleshooting 5 March 16, 2009 12:39 PM
stuck sensor? kyle_L Troubleshooting 2 March 13, 2009 11:13 PM
Odd Sensor readings. Dethredic Overclocking, Tweaking and Benchmarking 15 October 29, 2007 08:08 PM
