Old March 3, 2010, 10:30 AM
wonton1017's Avatar
Originally Posted by gingerbee View Post
um form what i can tell anything over 4 cores is going to be socket 1366 not 1156. and after pricing them out new from ncix the 920 1366 setups are cheaper. so i say the 920 1366. and yes this is with a good Board in both builds with 6 gigs. jm2cents
They may be cheaper at NCIX, but the i7 920 combo here will technically cost me ~$60 more.
Old March 3, 2010, 10:33 AM
gingerbee's Avatar
60$ that's it then take the 920
Old March 3, 2010, 11:04 AM
wonton1017's Avatar
You guys make it so hard for me to decide x.x
Not sure if this would be a smart move or not but what if i can sell my i7 860 + motherboard and get an i7 920 d0 + a x58 motherboard for the same price?
Old March 3, 2010, 11:37 AM
MonsterSound's Avatar
ha! That's probably what I might do (now considering the other parts involved).
Even though you will likely pay some more for a new i7 920 (or 930) & MB than you would get for your 860 & MB, the difference would be minimal and that way you get the other stuff that you want.
Plus you get a chance to play with the 860 and you might just stick with it for a bit (especially if you're waiting for decent offers for the 860 & MB.)
As mentioned by Fudd Rucker earlier, the 860 is no slouch at all.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old March 3, 2010, 11:44 AM
wonton1017's Avatar
Yeah, my friend has had the i7 860 and i7 920 both to 4.0ghz and he said in gaming application start-ups performs the same, but i guess even though right now they may be at the same price but the resell value will probably be higher for the i7 920 and x58 combo later on...
I don't do anything else other than gaming from time to time...
Probably going to have this decided by tomorrow.
Old March 3, 2010, 11:53 AM
gingerbee's Avatar
price it out at ncix it's cheaper for the 920 as long as you don't want a 400$ board then your good. which is not needed
Old March 3, 2010, 12:38 PM
performance is about the same but
if you wanna crossfire or sli get the 920
if you wanna overclock past 4.2get the 920
if ya wanna just save $ get the 860
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
what would this combo be worth ? bc_tileguy Off Topic 6 January 14, 2010 12:56 PM
[WTB] Looking for cpu+board combo. Silvgearx Buy/Sell & Trade 0 January 12, 2010 08:17 PM
[FS] CHEAP i7 Stuff (x58 Mobo + 6gb tri-chan DDR3-1800 ram + i7 920) ComBo DEALl! Saibot Buy/Sell & Trade 14 July 11, 2009 06:10 PM
Best Case+PSU Combo? curtispan Cases 10 June 26, 2009 12:33 AM
[FS] [FS]for sale combo local only gingerbee Buy/Sell & Trade 17 March 16, 2009 06:36 AM
