Old February 28, 2010, 03:00 PM
Default My e8400 temps...
Hey guys, I was just wondering if my e8400 is running hotter then it should be...
I want to get this thing 24/7 4ghz but my temperatures are getting a little high.
I'm using an OCZ Vendetta 2 cooler in a CM Centurion 5 case.
Is this cpu running hotter then it should be?
Any tips?
Old February 28, 2010, 04:36 PM
gingerbee's Avatar
I would be more concerned about your gpu. no your temps are fine as long as your max temps there where done with prime95 or occt?
Old February 28, 2010, 04:43 PM
I have a 4850 from the first ish wave with the bad coolers so the gpu's heat isn't a problem. The max temp was found using IntelBurn Test, an alternative cpu stress tester.
Old February 28, 2010, 04:46 PM
gingerbee's Avatar
temps are fine
Old February 28, 2010, 04:54 PM
So this thing couldn't really get a nice 4ghz overclock safely?
Old February 28, 2010, 05:21 PM
gingerbee's Avatar
the way i would run it is anything below tjmax 20c or lower is not good. so it looks like you can go for more try and see what your temps go to and what you comfortable with
Are these temps ok for an E8400? Gameplaywarrior Overclocking, Tweaking and Benchmarking 12 August 2, 2009 11:10 AM
E8400 Idle temps? Realityshift Air Cooling 12 May 23, 2009 01:58 PM
Temps for E8400 on W/C clearly off... Barber Water Cooling 18 April 6, 2009 10:02 AM
E8400 temps miggs78 CPU's and Motherboards 14 September 8, 2008 05:36 PM
E8400 Idle Temps... rjbarker Overclocking, Tweaking and Benchmarking 13 April 14, 2008 02:36 PM
