Originally Posted by hohohee instant help plz!!! i put the paste... now i put heatsink which i already put on the heatsink tighter/holder in the heatsink before i put in the cpu.... now i put... now cant screw! it wont tight! it seems short but how? did i not supose to put the tighter on first? did i put the tighter on last? help!
its like the bolt is too short! i cant screw it down! help!
more info.... you know the yellow colored plastic part of the heatsink bottom? yeah i cant screw that on the motherboard. the bolt seems short and loose. theres also this metal lock that clip and i already clip on both side. i cant scre wthe molt to the motherboard..... help! |
Picture? That might help us understand the problem.
ST
