  #21 (permalink)
Old February 22, 2010, 10:10 PM
Raserei408's Avatar
Entirely possible...though I've never understood why anyone wouldn't want the flexibility of being able to remove the heatsink...ever...
The thought crossed my mind reading the thread for sure, but it seemed like old thermal paste that was really hardened on was a more likely answer.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
  #22 (permalink)
Old February 22, 2010, 11:12 PM
Caldezar's Avatar
Ummm... did I read the original post right in that you removed the CPU from the socket WITHOUT unlocking the lever that locks the pins in place? If so, you're gonna want to make sure you didn't break off any pins, Espescially since you mentioned you had to yank on it to get it out of the socket. The cpu should come out nice and easy, no forcing necessary.
Here's an illustrated guide... Although the product is outdated, and you should apply thermal paste to the entire cpu on newer models, the steps are still the same.
  #23 (permalink)
Old February 23, 2010, 12:08 AM
Guys come on.. this happens ALL the time as you unlock the cpu hsf ESPECIALLY on amd or older intel where they used the zif sockets it was QUITE normal for this to happen.
Its usually because the hsf had never been separated from the cpu before and it dries up and gets reallllllllllly sticky.
This is why I said check for bent pins for as I have had this happen NUMEROUS times that I can't even count anymore.
Besides ... how do you REMOVE the cpu from the socket unless you remove the hsf first?
  #24 (permalink)
Old February 23, 2010, 02:19 AM
reaverclan's Avatar
this happened to me in shop class once long time ago, u need to heat up the heatsink and cpu with a hairdryer or something not a flame lol. it will let the two separate.
  #25 (permalink)
Old February 23, 2010, 10:33 AM
Soultribunal's Avatar
QFT on this one. I've seen old TIM that resembeled Glue and I've yanked a CPU out with the HS still attached. It does happen. Just make sure you inspect for any obvious signs of Damage.
ST
www.realhardwarereviews.com
  #26 (permalink)
Old February 23, 2010, 10:36 AM
MarkOne's Avatar
hum hummmmm
Originally Posted by MarkOne View Post
....... it's probably only the thermal paste holding it. it happen with zif socket to see the cpu go out with the cooler,.
  #27 (permalink)
Old February 23, 2010, 12:00 PM
Perineum's Avatar
I've had numerous cpus come out with the HSF. The TIM dries out after a while and more like hardened clay. I've never had a problem with bent pins, however.
Err, so yeah, they didn't glue it on, or at least it's VERY unlikely. I mean only a complete idi... ahh hell. Nevermind.
  #28 (permalink)
Old February 23, 2010, 05:27 PM
Sushi Warrior's Avatar
I am mostly confused by the fact that he never mentioned opening the latch.... unless I missed something.
  #29 (permalink)
Old February 23, 2010, 05:31 PM
Spikemaul's Avatar
Not being rude but I would like to know how he is an MVP of this site and never taken a CPU out before?
  #30 (permalink)
Old February 23, 2010, 09:34 PM
Perineum's Avatar
Nothing confusing about it.
With the latch down on a ZIF socket (IE: the sockets with the levers) you can, without too much effort, pull the CPU straight out of the socket.
It's not locked in.
taking off back case fan to put on cpu cooler? edisleado Air Cooling 5 February 8, 2010 08:39 AM
taking it way to far gingerbee Off Topic 22 July 28, 2009 07:27 AM
[FS] Upgrade time MB, CPU & video card aimndtel Buy/Sell & Trade 15 November 28, 2008 09:54 PM
Please Help, First time Swapping a CPU/Mobo into new case! bushwickbill CPU's and Motherboards 18 July 24, 2008 05:21 PM
CPU Burn-in time Bognostraglum Troubleshooting 7 April 28, 2007 08:25 AM
