Old February 22, 2010, 02:45 PM
Originally Posted by hohohee View Post
awww man so its official.... i need to take cpu and heatsink apart and put thermal paste.....
cant i use regular glue? likle super glue? if not... can i put nothing?
if i must put thermal paste.... will this thermal paste do? Amazon.com: StarTech HEATGREASE Thermal Conductive Grease for Heatsink: Electronics
yeah i should not remove it if i dont have thermal paste at hand but my plan was just taking out heatsink and clean dust but unexpectly pull the cpu along with it but yeah next time if pull heatisnk... gotta have thermal paste at hand jus in case pull cpu with it.
Its not glue
Its dried up thermal paste from being there far too long.
Just get some AS5 or something I'm sure a local store will have it.
Old February 22, 2010, 02:47 PM
It's not glue. It's paste which is meant to transfer heat more effectively between the CPU and heatsink. You cannot use glue. You have to use proper thermal paste.
This would be a better choice: Amazon.com: Arctic Cooling mx-2: Electronics
If you ever remove the heatsink from the CPU, you have to reapply thermal paste even if you don't take out the CPU as well. Any time you disrupt the contact between the CPU and heatsink, you should replace the paste.
Old February 22, 2010, 02:55 PM
gingerbee's Avatar
LOL lol
Old February 22, 2010, 03:00 PM
ahhh ok. lesson learned. never knew must put new thermla paste when take out heatsink too.
thermal paste your link is pretty expensive... 8.00 for a small thing. hmmm. the differenc eis quality right? the 99 cents can be used? but not as effecient as the 8 dollar? if so... ill buy the cheap one first and see how it is.
alright i think im settled. buy thermal paste and back on track. lazy to buy local shop and its probly cost alot. ill buy online and dont have pc for 3,4 days but its ok i have multiple pc plus i spin more time on ps3.
so yeah apreciated helps.
ps. someone said AS5.... i thought ASS haha.
Old February 22, 2010, 03:16 PM
bojangles's Avatar
$8.00 for a thing of paste will last a long time. You do not need to apply very much. Rice grain/pea size is enough. You only need to reapply if temperatures are going up. I haven't changed mine in over a year on one of my computers.
Old February 22, 2010, 04:03 PM
Watch this video on how to put thermal paste on your cpu. He shows you how to do it on an Intel and AMD cpus. YouTube - Installing Thermal Compound (NCIX Tech Tips #11)
Also if you are having trouble getting the CPU off the heatsink try using a blow dryer and aim it around the bottom of it. That should heat it up enough for the thermal grease to soften and allow the cpu to separate from the heatsink. I've used this method before on a socket 478 CPU.
good luck
Old February 22, 2010, 05:31 PM
Some tips if you have to do it again.
Heat up cpu before removing hsf.
Store as5 nose down when not using.
Coffee filters are also lint free and can be used to clean cpu and hsf.
Hope it works out for you.
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old February 22, 2010, 08:00 PM
Sushi Warrior's Avatar
Make sure to apply peanut-butter to the CPU socket
/sarcasm
Good luck, seems odd you CPU would pop out.... isn't there a bracket/latch holding it in?
  #19 (permalink)
Old February 22, 2010, 08:46 PM
BT!'s Avatar
BT! BT! is offline
how do you have 300+ posts here and not know about thermal paste... glue? really..
  #20 (permalink)
Old February 22, 2010, 09:39 PM
howpet's Avatar
I wonder if someone in the past might have been silly or stupid enough to apply thermal adhesive instead of thermal paste?
taking off back case fan to put on cpu cooler? edisleado Air Cooling 5 February 8, 2010 08:39 AM
taking it way to far gingerbee Off Topic 22 July 28, 2009 07:27 AM
[FS] Upgrade time MB, CPU & video card aimndtel Buy/Sell & Trade 15 November 28, 2008 09:54 PM
Please Help, First time Swapping a CPU/Mobo into new case! bushwickbill CPU's and Motherboards 18 July 24, 2008 05:21 PM
CPU Burn-in time Bognostraglum Troubleshooting 7 April 28, 2007 08:25 AM
