Old February 20, 2010, 08:42 AM
matsta31's Avatar
Default computer without a case power button
Hi,
My latest build is without a case and my mobo does not have integrated power-reset button. I am looking ofr the easiest solution, building a solution could be possible, but if it is cheap, I prefer buying it.
I found one on the web, but cant find one in canada :
HSPC ATX Control Kit at Xoxide!
anybody got a solution they use ?
Sold hardware again.....
Currently using WHS hardware....
Old February 20, 2010, 08:45 AM
Arinoth's Avatar
Yeah, i used an old case connector for sound from the mobo to the case. Cut off all the connections, wired up/soldered a push button onto it and voila, thats whats been used in my atom sega genesis build
Here I am: here I remain
Old February 20, 2010, 08:49 AM
matsta31's Avatar
I dont have an old case.... Maybe I could find one some from a frien but not for now...
Old February 20, 2010, 08:51 AM
Take a screwdriver and short the pins for the power switch on the motherboard? That's how I do it.
Old February 20, 2010, 08:52 AM
matsta31's Avatar
lol, why not :)
Old February 20, 2010, 09:05 AM
JD JD is offline
Yup same here. Works fine.
Old February 20, 2010, 09:10 AM
chrisk's Avatar
Folding Captain
I just use a jumper lying around.
Fold for team #54196
Old February 20, 2010, 09:16 AM
Fudd Rucker's Avatar
I use whatever is metal that will jump it. Got a good giggle one thanksgiving diiner when I used the gravy ladel to turn on my pc.
I couldnt think of something snarky or interesting to put here this time around.
Old February 20, 2010, 09:20 AM
MarkOne's Avatar
do you need something semi-permanent or just a solution to boot it ?
Old February 20, 2010, 09:23 AM
matsta31's Avatar
I would prefer semi permanent if it is cheap... if not, just booting is enough.
Asus P6T power up with button on case Tiger CPU's and Motherboards 4 August 23, 2009 08:17 AM
When I hit the power switch the computer doesn't respond! andynerd Troubleshooting 22 June 25, 2009 05:03 PM
[WTB] Computer Case and 550watt power supply at minimum. kazyn Buy/Sell & Trade 15 May 25, 2009 06:38 PM
power/reset button and cable magictorch Cases 2 November 28, 2007 01:09 PM
