Old November 6, 2006, 05:56 PM
Gav's Avatar
Gav Gav is offline
Administrator
Post INQ takes a look at an AMD 4x4 system
http://www.theinquirer.net/default.aspx?article=35535
Nothing to spectacular about the article, but interesting none the less.
Old November 6, 2006, 07:48 PM
Misoprostol
Guest
Posts: n/a
One really big problem I see with the whole 4x4 idea is that anyone who wants to use phase change or any other kind of exotic cooling is going to have to have TWO such units. Not very practical.
Old November 6, 2006, 09:51 PM
UNESCO's Avatar
I think phase-change and practical are mutually exclusive myself. ;)
Old November 13, 2006, 05:54 PM
It's a bit silly in my opinion. What's the TDP rating on the the higher end X2 parts these days? If power consumption is +100w more then you are going to have heat issues with an overclocked system, nevermind the interaction between two overclocked physical processors.
Old November 14, 2006, 08:32 AM
Misoprostol
Guest
Posts: n/a
I believe that the new FX 7* series processors will have a TDP above 100W. it's going to be pretty insane. Water cooling is going to be a whole new ball game with two processors and two SLIed video cards.
My Computer takes 4 ever to load kcksteve Troubleshooting 13 October 16, 2007 03:50 PM
About to build a new system Nimbus CPU's and Motherboards 10 October 12, 2007 10:55 PM
New System! :) Kandorf Troubleshooting 2 October 3, 2007 03:24 PM
I need some help with a new system SirenOfDarkness Troubleshooting 0 September 7, 2007 07:51 PM
New System - Need help Sameer CPU's and Motherboards 27 April 29, 2007 10:15 AM
