Old February 15, 2010, 01:08 PM
You could always improvise with your own small mods like using your own bolts to do this. Or you could cut 4 strips of metal out for backplate, drill the holes at the right places and bolt it through.
Old February 15, 2010, 01:13 PM
BT!'s Avatar
BT! BT! is offline
forgot to update this.. i think this will work.
after i stopped being a dumb-ass and realized the 1366 backplate i have with the true was flat rather than beveled in at the center like the 775 backplate i'm sure it will straddle that no problem. the 1156 is flat too.
just had a bit of a brain fart, lol.
Old February 17, 2010, 12:03 PM
BT!'s Avatar
BT! BT! is offline
the 1156 kit worked fine :)
Old February 19, 2010, 11:26 AM
Trial Member
I use a 212+ on my p55 FTW.
Old February 19, 2010, 01:05 PM
BT!'s Avatar
BT! BT! is offline
my true seems to be holding its own :P
77c is a little higher than i would like but... at 25c ambient its not to bad for a 4.2ghz on air.
Old February 19, 2010, 02:28 PM
gingerbee's Avatar
not bad at all ah 4.2. those temps are fine.
Old February 19, 2010, 04:40 PM
headsh0t's Avatar
Nice! I've been trying to get mine up to 4.2 but so far no luck :( What other settings are you running in your BIOS?
Old February 19, 2010, 05:32 PM
BT!'s Avatar
BT! BT! is offline
at 4.0 it will run with 1.33750v, did 4 hours of prime and 2 of occt. but at 4.2 it went for about 3 1/2 hours in prime with 1.4v in bios, then froze so i put it back to 4.0 and 1.33750 to play a bit of bfbc2. i'm just about to try another 4.2 run in prime with 1.40625v.
  #19 (permalink)
Old February 19, 2010, 06:07 PM
headsh0t's Avatar
Ya I don't really use P95 anymore cause like you said it can go fine for hours but still not be stable. I just use Burn Test and then maybe do some gaming and folding and that'll pretty much tell you if it's stable or not. Apparently Linx is the program to use now too, but I havent used that yet. So are you just changing vcore or are you changing VTT and PPL voltages?
EVGA P55 FTW NO CROSSFIRE BRIDGE?? muffler CPU's and Motherboards 14 January 26, 2010 07:28 AM
EVGA P55 FTW WITH FOXCONN muffler CPU's and Motherboards 15 December 23, 2009 02:50 PM
EVGA P55 Mobo Lineup Revealed + P55 FTW Preview Comment Thread SKYMTL CPU's and Motherboards 11 August 22, 2009 10:31 PM
