Old January 31, 2010, 12:00 PM
gingerbee's Avatar
the orientation is the same in all picks you just turned the pic
Old January 31, 2010, 01:25 PM
ZZLEE's Avatar
Default 40mmx20mm
You could try 2 40 by 20 mm zip tied to the other side of the heat sink on the bridge. I have seen pictures of this at EVGA forums. :)
Old January 31, 2010, 02:22 PM
vintank's Avatar
lol damn I uploaded the wrong one
sorry about that, was being rushed out the door by my wife
I will check that out ZZLEE
edit: well went through all the pictures and the one I took with the orientation that I wanted is no where to be found, sorry guys
I am going to keep it like this and see how it performs, hopefully once I get everything overclocked and stress tested it performs as it should.
my only other concern is the video card but I don't overclock so as long as my air flow in the 800D is good it should be fine.
EVGA X58 Classified 3 SLI / i7 920 D0 / Corsair XMS3 DDR3-1600 2gb x 6 / Noctua NH-D14 / eVGA GTX 680 / Corsair Obsidian 800D / Be Quiet Dark Power Pro 850w
EVGA P55 Classified, EVGA X58 Classified, Core i7, New SATA? -ConfuseD- TokeR New Builds 8 December 7, 2009 12:13 AM
EVGA Announces GTX 285 Classified and X58 Classified 4-Way SLI Motherboard voklskier4452 Press Releases & Tech News 38 September 9, 2009 03:17 PM
EVGA X58 Classified GIVEAWAY!!! somecanadianguy CPU's and Motherboards 40 May 31, 2009 10:35 AM
EVGA X58 Classified belgolas CPU's and Motherboards 121 April 6, 2009 04:52 PM
X58 Classified Question rjbarker CPU's and Motherboards 7 March 20, 2009 07:28 PM
