<~----> suggest an AM3/AM2+ mobo - Hardware Canucks
Old January 28, 2010, 07:46 PM
Mook06's Avatar
Default suggest an AM3/AM2+ mobo
So Ive been looking for a mobo for a few weeks now, almost settled on Newegg.ca - Foxconn A79A-S AM2+/AM2 AMD 790FX ATX AMD Motherboard - AMD Motherboards
but it doesn't seem to fair well with unlocking hidden cores
-I plan on using a Phenom II 550 so unlocking is one of the bigger requirements
-DTS Connect is a requirement, may as well get this onboard, cheaper than getting a dedicated soundcard and the sound quality will be identical using digital
(Dolby Digital Live would suffice but i prefer DTS)
-ATX size, dont plan on crossfire but i would like the extra slots, my current matx + dual slot 8800gt fills the board, drives me nuts
everything else is up in the air
the hardest info to find seems to be if the Sound chip/driver supports DTS connect, any help finding me a board much appreciated.
Old January 28, 2010, 07:48 PM
Your budget would be helpful.
"What is the colour when black is burnt ?" - Neil Young
Old January 28, 2010, 08:00 PM
Mook06's Avatar
ah yes, around 150can would ideal
Old January 28, 2010, 08:38 PM
0o0 0o0 is offline
m4a79 deluxe. I've got the m4a79t deluxe and I love it. It lacks dual ethernet, but who bothers going through all that hassle anyways? I also have a m4a785td-v evo that also unlocks very nicely, but voltage regulation isn't as good as the m4a79t (even though they're both 10 phases). yes I'm an asus fanboi, I've had one gigabyte board and it was buggy as hell, but it was a $60 budget board
Raserei408's Avatar
I'd say the M4A79XTD Evo. Not too sure on the DTS, but it fits your other requirements nicely. Besides, dual slots, though not necessary, are really nice to have.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old January 28, 2010, 08:52 PM
Mook06's Avatar
thanks guys, ill check those out right now
Old January 28, 2010, 09:50 PM
Mook06's Avatar
either of those dont seem to support dts connect nor ddl, the search continues
i really wish mobo manufacturers listed audio capabilities better, dts connect/dolby digital live is the only way to get surround sound out of games over spdif
i may have to get a cheaper mobo and a legacy-pci soundcard and slap it in the bottom slot
Old January 29, 2010, 06:21 AM
I picked up that same Foxconn board you're looking at. Runs great so far and has great overclocking ability, very simple to use. I'm just worried down the road if all the phenom IIs and new X6's will be fully compatible as I haven't heard anyone running a 965 on it (only as high as a 955). I'm not sure how good this board is at unlocking cores but I'd like to hear the results . The Gigabyte UD4P seems to be the king at that ability. Either way the board you selected is not too shabby at all, especially for the price!
Old January 29, 2010, 09:37 AM
Soultribunal's Avatar
+1 I run both EVO's and I love them!
ST
Old January 29, 2010, 12:41 PM
sswilson's Avatar
Probably the best way to start this would be to use google to find out what onboard audio chips support your requirements and work from there.
[FS] Cheap Trio: AM2/AM3 Mobo + 2GB DDR2 + 640GB HDD MAC Buy/Sell & Trade 28 October 11, 2009 10:05 PM
AM2+ hsf fit AM3? mattlef CPU's and Motherboards 1 July 31, 2009 05:36 PM
[WTT] e5200 lapped for your AM2/AM3 CMetaphor Buy/Sell & Trade 12 July 15, 2009 05:23 AM
[WTB] AM2+/AM3 MB must have AMD chipset aimndtel Buy/Sell & Trade 5 June 13, 2009 11:36 AM
[WTB] WTB: AM2 or AM2+ mobo and ddr2 ram Table21 Buy/Sell & Trade 0 February 3, 2009 11:29 AM
