Well, if you're thinking about OCing, getting a good cooler is more important than a case. Generally, good "OCing cases" have plenty of fans and vents for airflow, but as long as it has 3-4 120mms I'd say it's perfectly fine (any more and it will just be loud). Also, I don't recommend the Antec 300 or 690. If you really want to go inexpensive I'd say get the NZXT Beta EVO or Gamma. The 690 II is great if you can afford it though; it's a little light on included fans, but it's got plenty of slots and adding some as you go along will give you some really great airflow.
Also, there's an expected video card drop when Fermi is released in a couple months. If you've got a card already that you can carry over until then (or are willing to hold off) you'll likely save a good amount on your video card. Personally, though, I wouldn't say it's worth putting off the build entirely.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
