Old January 28, 2010, 01:35 AM
Default Major differences between Gigabyte P55A-UD4P and UD3?
I've already made up my mind to go with an Core i5 750 despite thinking alot about going with AMD. Anyways, I'm not sure which board to get to pair with the i5 750. If I'm on a budget and am adamant with Crossfire, should I stick with the P55A-UD3? I save at least $40 by going with that solution. I'm not convinced that the extra capabilities including SLI on the UD4P is worth the extra money. I'm just looking for a board and RAM combination such as the G.skill Ripjaws to increase the odds that I'll get a 4ghz oc with the i5 750. So what should I do?
Old January 28, 2010, 07:01 AM
gingerbee's Avatar
i like the udp4 but it jmy2cents. the chip is what will hold you back from your 4ghz i think any of these boards will do fine for your OC.
comparison sheet http://www.giga-byte.com/Products/Mo...ctID=3238,3242
Old January 28, 2010, 07:08 AM
MonsterSound's Avatar
If you're not for SLI then the UD3 is a good board. I had my i5 750 at 4.2 on air easily with the P55-UD3R. i5 750's overclock more easily than i7's imho. No HT means less power needed, less volts = less heat.
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old February 3, 2010, 03:03 PM
CraigRT's Avatar
Did you review your Anandtech posting? :p
i7 860 + Hyper 212
P55A-UD4P F14
8GB Mushkin Silverline
Powercolor 5870
Velociraptor 150
Seagate LP 2TB
Corsair AX750
Silverstone FT01B-W (HWC review case)
HEATWARE 45-0-0
My Cannondale <3
Old February 3, 2010, 04:02 PM
MarkOne's Avatar
Can't say better, when I buy the kit of Mike ( I think it's Mike , sorry for the memory) the same board and CPU as you , and it was on the same clock too, now I run my 860 on the board , and the 750 is on my gaming Asus board. the only complain I have is an incompatibility with the G11 keyboard , but only when I play in the bios . But I have an easy turn around
GIGABYTE GA-MA770-UD3 Motherboard Review Comment Thread MAC CPU's and Motherboards 16 August 13, 2011 01:10 AM
Request Review: Gigabyte MA770-UD3 jcmaz Reviews & Articles from the Web 14 March 24, 2010 06:20 AM
Help overclocking my Gigabyte GA-MA770-UD3 Nateiscool Troubleshooting 12 December 22, 2009 09:52 PM
[FS] FS: Gigabyte P55 UD4P Eldonko Buy/Sell & Trade 12 November 28, 2009 07:22 PM
