Old January 27, 2010, 08:24 AM
Default Budget build x2
My wife and I are casual WoW gamers and need to get caught up to this decade in tech... Well, half decade anyway...
We're currently running AMD 3800+x2 with 2g DDR.... so you can see/feel our pain.
My taxes will be $1200 and I need to stay under that for two builds. Good news is, I don't need everything. Just the "guts". Incoming list...
Newegg.com - Rosewill Green Series RG700-S12 700W Continuous @40°C,80 PLUS Certified,Single 12V Rail,ATX12V v2.3 / EPS12V v2.91,SLI Ready,CrossFire Ready,Active PFC"Compatible with Core i7, i5" Power Supply - Power Supplies
Rosewill Green Series RG700-S12 700W "Compatible with Core i7, i5" Power Supply
$69.99
Newegg.com - Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Computer Cases
1Antec Three Hundred Black Computer Case
$59.99
2x Microsoft Windows 7 Home Premium Upgrade
$219.98
Newegg.com - G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ - Desktop Memory
2x G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory
$209.98
Newegg.com - GIGABYTE GA-MA770T-UD3P AM3 AMD 770 ATX AMD Motherboard - AMD Motherboards
2x GIGABYTE GA-MA770T-UD3P ATX AMD Motherboard
Item #:N82E16813128392
$159.98
Newegg.com - AMD Phenom II X2 550 Black Edition Callisto 3.1GHz 2 x 512KB L2 Cache 6MB L3 Cache Socket AM3 80W Dual-Core Processor - Processors - Desktops
2x AMD Phenom II X2 550 Black Edition 3.1GHz Socket AM3 80W Dual-Core Processor
$181.98
Newegg.com - Western Digital Caviar Blue WD3200AAJS 320GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Western Digital Caviar Blue 320GB 3.5" SATA 3.0Gb/s Internal Hard Drive -Bare Drive
$47.99 (My current is SATA I - can't have that)
Newegg.com - SAPPHIRE 100286L Radeon HD 4860 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Desktop Graphics / Video Cards
2x SAPPHIRE Radeon HD 4860 100286L Video Card
$248.00 (Chose this card per review from HWC. I'll Oc is a little)
Grand Total:$1,197.89 (w/ shipping)
I just want to make sure I get the bang for my buck. The items listed are the ones I need to replace to get us both up to speed. Discounts and deals may change between now and two weeks from now when I get the cash.
I'm also considering buying two dell refirbished machines. I can get nice ones for $450-$500 USD.
Thanks for your help. Can't tell you how much I enjoy these forums.
First Build - Budget Gaming BahKoo New Builds 16 January 1, 2010 06:06 AM
New budget build Evylldemon New Builds 6 July 19, 2009 05:01 AM
Budget build! JMCD New Builds 10 April 17, 2009 07:25 PM
need advice on budget build thenewguy001 CPU's and Motherboards 11 May 19, 2008 02:08 PM
Budget PC Build BALISTX CPU's and Motherboards 13 March 6, 2008 08:52 AM
