Old January 26, 2010, 09:23 PM
Default remove tim stain from cpu?
I just took a part a 5 year old build with a P4 and the stock heat sink. I cleaned it up with 90% alcohol but there is still tim on cpu. Is there a stronger solvent or something I can use to get it off?
Old January 26, 2010, 09:33 PM
ZZLEE's Avatar
Default Lap it
Lap it :) Glass plate or steel plate and lapping compound. EDIT:Lapping Accessories - Lee Valley Tools
Old January 26, 2010, 10:02 PM
rather not.. any other way?
Old January 26, 2010, 10:08 PM
BT!'s Avatar
BT! BT! is offline
did you try a coffee filter and alcohol?
Old January 26, 2010, 10:56 PM
go on......?
Old January 26, 2010, 11:16 PM
ZZLEE's Avatar
Default filterpaper is abasive
Take coffe fiter paper lay on a glass sheet or other flat clean surface, Use a fome block fore the back of chip add alcahol rub chip face on the paper. You can rap a small flat object in filterpaper and do it seated but don't use alcahol or as much alchol. Finish off by rubbing with filter paper with no alchol. :)
Old January 26, 2010, 11:51 PM
ZZLEE's Avatar
YouTube - CPU Lapping Guide (Part 1 of 2) good vid on lapping :)
HD 5870 Size ? = Remove HDD Bays JORD4N Video Cards 2 October 3, 2009 05:54 PM
TIM Selection NyteOwl CPU's and Motherboards 3 August 22, 2008 02:40 PM
I can't remove my side panel... Slinger Troubleshooting 5 February 29, 2008 11:26 AM
Do i need to remove V-droop with the voltage dampner magictorch Troubleshooting 1 January 19, 2008 07:16 PM
How to remove the air inside tube? francois methot Water Cooling 18 August 6, 2007 07:23 AM
