Old January 26, 2010, 07:29 PM
Default higher than 1600 fsb?
so ive got my cpu fsb at 440x8 for the q6600 but im worried becuase my gygbyte p45 ud3l is only rated for 1600 as per the box. Should i lower raise the multi and lower the fsb loosing around 500 3d mark 06 points or leave it, will it harm my motherboard. The northbirdge heatsink is too warm so i installed a delta 120cfm fan which i keep on low, than turn it full when i game, it really cools off the northbridge. It just kinda funny becuase they advertise a 1333 ram configuration yet the only way to reach that is to go beyond the 1600 advertised fsb.
Old January 26, 2010, 07:42 PM
Silvgearx's Avatar
Just use the x9 muti and bump up the cpu speed, no doubt you get more points then a merely 500 points.
And most P45 can handle 1600+
Old January 26, 2010, 08:10 PM
it was good for a bit now it keeps on freezing no bsod just freezing, no point in doing that for such a little gain. i cant bump up cpu anymore as its the b3 the temps are high enough i think. Is it possible to oc my ram without raising fsb?
Old January 26, 2010, 08:27 PM
Yes, you can set a higher RAM speed without changing the FSB. But I suggest you do some proper tweaking and stress-testing before you kill something.
Old January 26, 2010, 09:16 PM
yeah i guess i put everything to auto and set the q6600 v core to 3.81 or something like that. It doesnt run at that all the time just when it needs it or spikes sometimes, as ive been monitoring the voltage. everything is fine but prime 95 shuts down after like minute, whats up with that?
Old January 26, 2010, 10:20 PM
What's up with that is that your overclock is unstable. And I suggest you go do a little reading about overclocking before you start playing with voltages, to make sure that you don't accidentally fry something.
Old January 26, 2010, 11:07 PM
i know all about the voltages man its just a matter of sitting down and taking the time out. I got it fixed it just under prime it fails really quick, but its not my main concern as i can run 3d mark 06 fine, ill get around to prime i still think its kinda pointless as ill never have to stress the cpu again like that.
Old January 27, 2010, 12:10 AM
If you can't pass Prime95, then your overclock quite simply isn't stable. It doesn't matter if you can run 3DMark. There could be all kinds of issues behind the scenes that are caused by an unstable CPU, and you won't know about them until you actually start having issues.
[FS] FS: 2x1gb OCZ ddr3-1600 2x2gb Patriot ddr3-1600 Razer copperhead MarcusFoX Buy/Sell & Trade 8 February 14, 2009 10:45 AM
Higher Mhz? BT! RAM 2 January 3, 2009 04:48 PM
Mushkin 6GB DDR3-1600 vs. Corsair 6GB DDR3-1600 ImmaPC RAM 10 December 31, 2008 01:54 AM
FSB won't get higher than 350 Mhz... CraigHf Overclocking, Tweaking and Benchmarking 18 July 19, 2008 11:20 AM
Is someone able to OC FSB higher than 300MHz on Kentsfield francois methot CPU's and Motherboards 13 April 23, 2007 10:44 AM
