-   -   920 vs w3520 (http://www.hardwarecanucks.com/forum/cpus-motherboards/28223-920-vs-w3520.html)
gingerbee January 26, 2010 01:37 PM
920 vs w3520
Ok I will be buying in the next few weeks and was wondering what people think about these 2 chips what would you buy the 920 cheap but does the xeon oc better. opinions please.:biggrin:
EDIT oh does only the w xeon chips work in desktop boards since the e and x series one's are low power?:thumb:
MarkOne January 26, 2010 01:53 PM
The question is , did the xeon have turbo boost ? I don't check so I don't know . you don't need it now but latter if you want sell it, or use an other place, it can be something useful
Zero82z January 26, 2010 02:36 PM
Both chips are basically identical. Go with whichever is cheaper.
gingerbee January 26, 2010 02:44 PM
Originally Posted by Zero82z (Post 323788)
Both chips are basically identical. Go with whichever is cheaper/
this was my thinking just wondering if the xeon would clock better thank folks:biggrin:
