Old October 7, 2007, 03:52 PM
sswilson's Avatar
Where are you located?
If need be there might be somebody local who'd be willing to pop over with a 1066 CPU to get you past a flash if necessary.........
Old October 7, 2007, 03:55 PM
p35's should not need a bios update at all! They are designed for 1333 cpus unlike the 965 which would require one.
Old October 7, 2007, 04:02 PM
I just received my system less than a week ago...
Intel E6750 (1333FSB) + Gigabyte DS3L and I did not experience any problems getting the system to post. On top of that, the RAM I ordered is supposed to run at 2.2v but the board is factory set to 1.8v and it still posted no problem. I've never used BIOS before and to be honest I really didn't change anything in it because I didn't know what I 'should' be doing. Essentially I looked at it, said, hey thats neat, then installed the OS, lol.
That said, if anyone has any suggestions for me to ensure that things are running at the proper timings and voltages and such, feel free to give me pointers. What program(s) do you suggest to check voltages and what not? And where can I download them? I was checking RAM voltages in BIOS but basically it didn't tell you the true voltage ... you could just +.1 ... +.2 ... from default settings. So I was worried I might burn it out by overvoltaging if it had already adjusted to what the RAM should be.
Old October 7, 2007, 04:32 PM
RAM voltages on Gigabyte boards is basically this:
Default 1.8v
+0.1 = 1.9
+0.2 = 2.0
+0.3 = 2.1
etc :D
Old October 7, 2007, 06:45 PM
3.0charlie's Avatar
You will have a very nice system. And don't worry about the BIOS flash, the last DS3L I bought was already sporting the latest BIOS.
Have fun building it!
John
Hydro-Quebec is salivating...
Old October 13, 2007, 02:49 AM
Thanks for all your input.
I just placed my order for the above metioned parts and am giddy to get this setup running. I'd also like to report, I love Directcanada.com as I waited a week to see if the price would change or I could find a local shop within same price range. And I was giddy to see they droped the price of the E6550 20$ and droped the 320gb Segate 15$ + I found a mail-in on the coolmaster cm 690. That temped me to upgrade my case at the same time.
So I'll be rushing home from work all week to see if puralator has stoped in yet
Cheers again for the help
Budget PC Build BALISTX CPU's and Motherboards 13 March 6, 2008 08:52 AM
Planned Budget System - Appreciate Opinions misterlarry CPU's and Motherboards 28 January 16, 2008 07:55 PM
Need some advice for a low budget PC ebdoradz CPU's and Motherboards 14 December 14, 2007 08:52 PM
My new budget-ish pc kcksteve CPU's and Motherboards 21 November 27, 2007 12:24 PM
Budget Gaming System Challenge BALISTX CPU's and Motherboards 21 March 13, 2007 10:30 AM
