Old January 24, 2010, 06:44 PM
AmuseMe's Avatar
Default Quick Question About Motherboard PCI-E
Okay, so I have a EVGA P55 FTW and my question is, when running a single video card, does it really mater what PCI-E slot I use? I have seen some people put the cards into their bottom most slot multiple times. However, wont the card only run at x8 as aposed to x16?
DEAD CA$H
Old January 24, 2010, 06:47 PM
I believe most if not all P55 boards will only run the second slot at 8x. The real question is whether or not it makes a difference, and the answer is usually not.
Old January 24, 2010, 06:49 PM
MarkOne's Avatar
if you put in in the last one , (bottom most slot ) as you said. it will run at x4, the board of the OP have 3 slot
Old January 24, 2010, 06:50 PM
AmuseMe's Avatar
What would be the best way to test this? Pop the card into the x16 lane, play a game, and than swap in down into another slot, play a game, and compare FPS?
DEAD CA$H
Old January 24, 2010, 07:16 PM
Run GPU-Z. It will tell you the number of lanes the card has access to.
quick question twleung RAM 5 January 24, 2010 03:46 PM
quick pci-e connector question? napier Power Supplies 2 June 28, 2009 09:50 PM
quick question gingerbee O/S's, Drivers & General Software 6 May 19, 2009 05:12 AM
quick question... omgwtf O/S's, Drivers & General Software 14 July 22, 2008 05:31 PM
Quick question Nodscene Power Supplies 2 July 7, 2008 11:27 AM
