Old January 21, 2010, 07:46 AM
Navi's Avatar
Default Is this possible: nvidia and ATI gpu simultaneously
Hey all,
I was wondering if it is possible to use an ATI vid card as the primary one, and keep a 9800GT in a secondary slot purely for folding purposes? The motherboard in question is the Gigabyte GA-MA790XT-UD4P. I'm kind of worried about driver conflicts, possibly a reduction in gaming performance?
I apologize if this has been asked before, searching the forum with "nvidia and ati" yields a crap-load of results :)
Thanks in advance.
P.S. the 9800GT is a bloody great folder!!!! Already ~350th position on the team :)
eVga P55 FTW | i5 760 @ 4ghz | 4GB G. Skill Eco CL7 | Gigabyte 7870 | CM 690 II
Old January 21, 2010, 08:43 AM
Synth's Avatar
I HIGHLY doubt it will work, but in the interest of science, if you have the hardware handy, give it a shot and report back !
Old January 21, 2010, 08:45 AM
Fudd Rucker's Avatar
Windows 7 and winxp will allow you to install 2 different GPU drivers without a problem , dont see why you couldnt fold with one GPU while using the other.
I couldnt think of something snarky or interesting to put here this time around.
Old January 21, 2010, 08:54 AM
MarkOne's Avatar
I don't like the idea of 2 different GPU driver in the same PC. It can only bring problem....
Old January 21, 2010, 09:16 AM
Navi's Avatar
Unfortunately, I only have the 9800gt, I have yet to buy the mobo (debating whether I should wait for 890gx) and the other gpu. I was thinking of getting a 5850, or maybe another used nvidia gpu from the BST forum here.
I agree, Markone, having two different gpu drivers installed makes my skin crawl.
Old January 21, 2010, 12:28 PM
tri5cui7's Avatar
Could you use the second graphics card in a virtual machine for folding?
Old January 21, 2010, 12:57 PM
Dr_BenD_over's Avatar
Fallen Folder
XP and Win7 should work fine.
All's well that's Haswell
Old January 22, 2010, 03:41 PM
Navi's Avatar
Thanks for the replies, fellas. Should be running 7 on the new machine once I get it.
Old January 22, 2010, 04:14 PM
I don't believe you can fold on GPUs from within a virtual machine. The latest version of VMWare Workstation does support hardware video acceleration, but I don't think anyone has tested it with folding. And any VM software that does not support hardware acceleration will certainly not be able to do it.
Old January 22, 2010, 04:49 PM
Soultribunal's Avatar
I do think it is possible. Not sure what you need to do though.
One of the staff here uses his onboard ATi GPU for his day to day stuff and a GX2 for folding and its run good so far.
ST
www.realhardwarereviews.com
Old nvidia GPU 1ce HardwareCanucks F@H Team 3 October 1, 2009 11:47 AM
first time with nvidia.... nvidia or ati? hohohee Video Cards 27 April 27, 2009 08:49 PM
New Members Folding with Nvidia/Ati Gpu 2 Client/ Some Tips Dashock HardwareCanucks F@H Team 43 January 4, 2009 03:39 PM
Nvidia GPU solder joints at a disadvantage over ATI Spaceman-Spiff Video Cards 8 September 30, 2008 05:14 PM
D-TEK Customs Fuzion GFX GPU Water Block for Most NVIDIA & ATI Video Cards Babrbarossa Water Cooling 4 April 14, 2007 09:12 AM
