Old January 22, 2010, 06:49 PM
geokilla's Avatar
Not sure about folding, but it is definitely possible. Though the gaming performance isn't as good as it is when using a single GPU.
AnandTech: Lucid?s Hydra Unleashed: Part 1
Old January 22, 2010, 06:53 PM
You don't need Hydra to do this.
Old January 22, 2010, 06:56 PM
MarkOne's Avatar
Originally Posted by Soultribunal View Post
I do think it is possible. Not sure what you need to do though.
One of the staff here uses his onboard ATi GPU for his day to day stuff and a GX2 for folding and its run good so far.
ST
what if you put the ati as gpu0 and the nvidia as gpu1 , you just don't fold with gpu0
I will try it on my Maximus III when I have an extra card, I may have one but someone here get it before me
Old January 22, 2010, 07:50 PM
bojangles's Avatar
Doesn't Windows 7 allow both Nvidia and ATI drivers to be installed simultaneously?
Old January 22, 2010, 08:04 PM
kendallcschm's Avatar
XP also allows for this.. :-P i think it will work.. i don't see any problems coming from this... well... any huge ones
Old January 22, 2010, 08:26 PM
bkh2's Avatar
I can't say for sure that you can actually run the two cards simultaneously, but I do know I've got both drivers installed right now.
EDIT: I'm running a GTX 275 so when I boot up, the Catalyst thing will tell me that I don't have an ATI card.
Old January 23, 2010, 12:20 AM
Yes. WDDM 1.1, which is the display driver model used in Windows 7, allows multiple display drivers to be active simultaneously.
Old January 24, 2010, 07:34 AM
Jackquelegs's Avatar
Affirmative. Have tried it with 4850 and 9800GX2. However! Drivers tend to blow up in some games
Iapetos
Zephyranthes
  #19 (permalink)
Old January 24, 2010, 11:58 AM
cozmosland's Avatar
why wont vista allow this..?
is there a work around?
  #20 (permalink)
Old January 24, 2010, 12:09 PM
jcmaz's Avatar
You can always buy the MSI Big Bang w/ the Hydra200 chip in it...
-Plato
Old nvidia GPU 1ce HardwareCanucks F@H Team 3 October 1, 2009 11:47 AM
first time with nvidia.... nvidia or ati? hohohee Video Cards 27 April 27, 2009 08:49 PM
New Members Folding with Nvidia/Ati Gpu 2 Client/ Some Tips Dashock HardwareCanucks F@H Team 43 January 4, 2009 03:39 PM
Nvidia GPU solder joints at a disadvantage over ATI Spaceman-Spiff Video Cards 8 September 30, 2008 05:14 PM
D-TEK Customs Fuzion GFX GPU Water Block for Most NVIDIA & ATI Video Cards Babrbarossa Water Cooling 4 April 14, 2007 09:12 AM
