-   -   what is bus speed (http://www.hardwarecanucks.com/forum/cpus-motherboards/27991-what-bus-speed.html)
kuziwk January 19, 2010 10:23 PM
what is bus speed
so my motherboard supoprts 1600 bus speed, what does this mean? I have patriot viper series ddr2 1066 ram, would this also mean my cpu FSB would have to be 500x7 to reach the full potential of my ram and achieve my 3.6 oc?
Zero82z January 19, 2010 10:46 PM
The FSB speed is equal to the base bus speed multiplied by 4 with Intel CPUs. 1600MHz FSB support means your motherboard will support CPUs with a bus speed of 400MHz, like the QX9770 for example. Most Core 2 CPUs use a bus speed of 266MHz or 333MHz, although lower-end CPUs use 200MHz and higher-end chips use 400MHz.
RAM speed depends on the specific FSB:DRAM ratio you set in the BIOS. If you use the lowest ratio, then the RAM speed will be double the bus speed, which would mean that in order to run your RAM at 1066MHz, you'd need a bus speed of 533MHz. However, you can use different dividers to obtain higher RAM speeds with lower bus speeds, so you can run your RAM faster while putting less strain on the chipset.
kuziwk January 19, 2010 11:10 PM
i have a gigabyte p45 ud3l i guess it says the fsb or whatever is 1600 so this means i cannot run my cpu at 500x7 becuase my motherboard wont support it? i should also mention its supports 1333+ ram whatever the hell that means becuse all i found was ddr2 1066 which i bought.
Zero82z January 19, 2010 11:13 PM
Your motherboard does not officially support it, in the same way that your CPU does not officially support being run at speeds higher than its stock setting. By exceeding the motherboard's rating, you're overclocking it, just like you would a CPU or a video card. It doesn't necessarily mean the motherboard isn't capable of it, but it does mean that you may have to do some tweaking to get it to run.
kuziwk January 19, 2010 11:21 PM
ahh fair enough, such as voltage and what not, but for a q6600 to reach 3.5-3.6 the best ratio would be 500x7 with my ram? is this the only way to have my ram run at its potential or even overclock it?
what i dont understand is why does my motherboard support such high ram frequences yet has an fsb wall of 1600
sswilson January 20, 2010 12:15 AM
Not quite the same thing.
Your memory will run at a multiple of whatever your fsb is. So if your FSB is 500 then the lowest your memory can run is 1-1 which works out to 500 X 2 = 1000. If you want your memory to run at a higher speed, you simply have to raise your memory multiplier so that it's running faster than 1-1. The limitation on memory speed on a C2D rig isn't the upper end, it's going over the max your memory can do because you can't do lower than 2XFSB.
kendallcschm January 20, 2010 06:43 AM
so what does this mean:
2600MHz Hyper Transport (5200 MT/s)
i wanna know the limits of my board:
Newegg.com - ASUS M3A78-EM AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard - AMD Motherboards
Zero82z January 20, 2010 12:51 PM
HT is AMD's high-speed interconnect and is completely different from what we are discussing in this thread.
