-   -   Rampage Extream Ram question. (http://www.hardwarecanucks.com/forum/cpus-motherboards/27849-rampage-extream-ram-question.html)
Chromey January 16, 2010 10:34 AM
WHere do i stick the2 sticks of ram for best performance...
white or blue?
2x2gb sticks.
Jd007 January 16, 2010 10:41 AM
It should be in the user manual.
Chromey January 16, 2010 10:49 AM
Now anyone else please.
rfielder January 16, 2010 11:24 AM
What he said...
Without knowing the brand and model of motherboard, that question can't be answered. Even if you provided the brand and model, unless someone has the same one, it is faster and easier to check your manual than wait for someone here to go hunting for an online manual and look it up for you.
3.0charlie January 16, 2010 11:31 AM
The manual won't tell you which slot to use for best performance. Either search online for the answer, or try it yourself and use SuperPi 32M to find out.
