Old January 15, 2010, 07:51 AM
jcmaz's Avatar
Default Upgrade: Athlon to AthlonII
Hey HWC,
Is it worth it to upgrade from a OC'ed to 3.0Ghz AMD Athlon 5200+ Brisbane to the newer AthlonII 240?
Also, does it matter which RAM slots i use (ex: 1,3 ; 0,2) because my RAM is blocking my HSF.
Thanks
-Plato
Old January 15, 2010, 07:56 AM
IMHO it's not worth it to go from a dual core to another dual core now (unless you can get the new Athlon II 240 for very little). Motherboards usually have a preference of 0, 2 DIMMs when only two are being used, but I've seen people running on 1, 3 config without problems on some motherboards.
Old January 15, 2010, 11:51 AM
jcmaz's Avatar
Bumps for more helps.
What i meant about the RAM is that can i use the slots furthest from the CPU socket so i use my Sunbeam Core Contact to push air instead of pulling air.
-Plato
Old January 15, 2010, 12:05 PM
clone63's Avatar
That's how I've got my RAM running, no problems here.
Old January 15, 2010, 01:38 PM
Raserei408's Avatar
I'd say you should wait until you can afford a PII x2 BE, then unlock it (that is assuming your motherboard has ACC) and give it a healthy overclock. An AII is better than an athlon, but not worth the price IMO.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old January 17, 2010, 03:28 PM
Probably not. Wait till you can get a Phenom II or at least an x3/x4 athlon II.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
New way of cracking AthlonII X3 Unknownm CPU's and Motherboards 3 December 15, 2009 08:57 PM
Athlon II X4 620? somecanadianguy HardwareCanucks F@H Team 9 October 4, 2009 01:31 PM
[WTB] Athlon XP 3000+ riotd Buy/Sell & Trade 6 April 28, 2009 02:45 AM
Athlon +6000 OC kcksteve Overclocking, Tweaking and Benchmarking 2 February 22, 2008 10:09 AM
AMD Athlon X2 4600+ 334th_Frenchie CPU's and Motherboards 10 June 8, 2007 09:50 AM
