Here is what I had posted (below) from a
similar discussion/thread (with more opinions which you might be interested in).
btw. I switched to the i7 860 only so I could fold bigadv units which require 8 threads. I was not disappointed at all with the i5 750.
Originally Posted by MonsterSound Just a couple of thoughts/observations.
I Recently swapped my i5 750 for an i7 860 and the 860 definitely runs hotter w HT on (as martin_metal_88 suggests).
I had the i5 at 3.78ghz (for the 8 weeks I used it) w stock voltage folding 24/7 and temps were never a problem w CM 212+ (never a freeze or BSOD). Did a few benches for fun on the i5 at 4.24ghz with 1.35v stable (IntelBurnTest, Prime95...), and I must say that the i5 is the easiest overclocker I've ever used.
I haven't played around OC'g much yet with the i7 860, but volts and heat are going up for sure and at lower speeds.
I've also noticed a few threads where gaming/benches are shown as improved with HyperThreading turned off (lower heat/volts - higher overclocks). Seems ironic to turn off HT on the 860, as you are then essentially running an expensive i5 750.
The i5 750 may be the econo performance deal after all.
2c |
