Old January 10, 2010, 08:43 AM
kendallcschm's Avatar
Default Best AMD processor
I am an AMD fan boy and i was wondering what the best AMD chip was for over clocking... currently my AMD Athlon 64 X2 5200 is not satisfying me.. it only went from 2.7GHz to 3.01GHz ... i am looking for 4.0GHz on air cooling.. :-P any suggestions?
Old January 10, 2010, 08:54 AM
Perineum's Avatar
Well it looks like you have an appropriate motherboard that will unlock the 550BE If so, that's a pretty good deal. With a Coolermaster Hyper 212+ you can usually get it unlocked to quad and then overclocked to 3.8ghz..... but there is a chance it won't at all as it's sold as a dual core.
Old January 10, 2010, 08:58 AM
jcmaz's Avatar
I would get get a 720BE or a Athlon II 620 Quad Core, but i would upgrade the PSU first.
-Plato
Old January 10, 2010, 09:00 AM
how would i unlock the quad core capability?
Old January 10, 2010, 05:08 PM
Raserei408's Avatar
Your motherboard needs SB710 or SB750, and you enable ACC in the BIOS. If it can be unlocked that would do it.
What's your budget and price range?
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old January 10, 2010, 05:22 PM
Perineum's Avatar
Err, I believe the 780 series chipsets will unlock as well...
I've unlocked the 550's on a Gigabyte MA790XT-UD4P which uses the AMD790X chipset.
But anyway, you change three things (including voltage) in the BIOS and you're off and running.
Old January 10, 2010, 05:56 PM
Caldezar's Avatar
+1 for the 550BE! Even if it doesn't unlock to a quad, you can usually OC them close to 4GHz as a dual, and that's nothing to sneeze at for a $110 processor. I think it's close to the best bang-for-your-buck processor out there. But you'll need a decent cooling solution on it. The Xigmatek S1283 is a nice cheap option.
Old January 10, 2010, 06:05 PM
Yes, but the chipset has to include one of the southbridges mentioned above.
Old January 10, 2010, 06:14 PM
Perineum's Avatar
Ha. Damn. I actually bought that particular mb because others had unlocked it using that particular one. Now I'm curious as to why the southbridge would be related to the unlocking... ?
Old January 10, 2010, 06:56 PM
Because the southbridge determines ACC support (I'm not sure why since AMD never actually disclosed what ACC is or how it works).
AMD Announces 40W Six-Core AMD Opteron EE processor FiXT Press Releases & Tech News 4 August 31, 2009 12:43 PM
AMD vs. Intel Processor's? Hail Ceasar CPU's and Motherboards 16 November 3, 2008 11:14 AM
Best AMD processor for 250$ vikrant.forums CPU's and Motherboards 7 October 5, 2008 08:46 PM
Which AMD processor should I get. BALISTX CPU's and Motherboards 9 December 22, 2007 04:46 PM
AMD Expands Upcoming Processor Branding: DailyTech Babrbarossa Press Releases & Tech News 0 June 4, 2007 06:48 AM
