Old January 10, 2010, 06:56 PM
jcmaz's Avatar
You need the 710 or the 750 southbridge in order to unclock cores. The reason why 780G some CAN unlock cores because they have the new revision of the 710 southbridge.
-Plato
Old January 10, 2010, 07:03 PM
Perineum's Avatar
This has got me really curious, as I believe ACC is Advanced Clock Calibration. I've never understood what it is or what it really does other than unlock cores. Kinda just took it for what it was and never asked the questions.
Old January 10, 2010, 07:07 PM
belgolas's Avatar
Remember it is not guaranteed to unlock to a quad core. My brother bought one and no matter how much voltages I put into it it wouldn't stay stable. But it is still a great dual core. But I would rather go with the 965 as it is a much better CPU and is still pretty cheap but it does cost more.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old January 10, 2010, 07:13 PM
Perineum's Avatar
Here we go. I found it confusing that a southbridge would be so involved with the processor but this explains it:
Motherboards equipped with the SB750 chipset has a new layout and sports a six-pin connection directly to the AM2+ CPU socket. These are the six pins that had been dormant. They makes it possible for the southbridge to override some of the processor's internal settings and thus increase the overclocking potential.
I agree. Especially that it can be had now for $190ish.
"What is the colour when black is burnt ?" - Neil Young
Old January 10, 2010, 07:25 PM
Perineum's Avatar
Originally Posted by Caldezar View Post
+1 for the 550BE! Even if it doesn't unlock to a quad, you can usually OC them close to 4GHz as a dual, and that's nothing to sneeze at for a $110 processor.
I get them to 3.8ghz as a quad, so 4.0ghz as a dual shouldn't be hard
However, the OP's motherboard has the SB700 chipset, and APPARENTLY* he needs a 710 or 750.
* As I have now learned
Old January 10, 2010, 07:45 PM
Raserei408's Avatar
The 955 is a much better buy. All you have to do is bump up the multiplier a small bit and it's identical to the 965 for $30 cheaper. And then, of course, you can keep going and run it a lot higher.
Also, as for a CPU heatsink, if you're overclocking, the S1283 (previously the heatsink of choice) has since been eclipsed by the Hyper 212 Plus. Better temps, lower price.
"If dancing is sure to result in failure then you must dance anyway."
Lo Mein said that, and I think he knows a little more about dancing than I do pal, because he invented it! Then he perfected it so that no man could best him in the club of honor.
Then he used his prize money to buy two of every whore on Earth. Then he herded them all onto a boat, then they all beat the crap out of every single one of him.
Old January 11, 2010, 08:26 AM
My thoughts also.
Gaming FX 8350 4.4GHZ / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.4GHZ/GA 970 Gaming/ Rx 580 8GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
  #19 (permalink)
Old January 11, 2010, 08:56 AM
A 955BE will go higher than a 965BE?
  #20 (permalink)
Old January 11, 2010, 06:07 PM
Silvgearx's Avatar
its all luck of draw like any other cpu
my unlocked x4 550 can clock better than a 955BE c2
AMD Announces 40W Six-Core AMD Opteron EE processor FiXT Press Releases & Tech News 4 August 31, 2009 12:43 PM
AMD vs. Intel Processor's? Hail Ceasar CPU's and Motherboards 16 November 3, 2008 11:14 AM
Best AMD processor for 250$ vikrant.forums CPU's and Motherboards 7 October 5, 2008 08:46 PM
Which AMD processor should I get. BALISTX CPU's and Motherboards 9 December 22, 2007 04:46 PM
AMD Expands Upcoming Processor Branding: DailyTech Babrbarossa Press Releases & Tech News 0 June 4, 2007 06:48 AM
