Old January 7, 2010, 05:10 PM
Default i3 540 for gaming
I guess that an i3 540 with a good cooler and overclocked to about 4Ghz would become a good CPU for gaming right? :)
Old January 7, 2010, 05:37 PM
Yes, it would be.
Old January 8, 2010, 07:30 PM
Why not the i3 530 ? Cheaper and pretty much the same OC results. I'm thinking about buying one -- 4.4GHz would be my goal.
Old March 25, 2010, 09:43 PM
i3 has GPU integrated on die... How to turn it off to get more thermal head room? Because I don't think that GPU can does gaming rendering... Add on Gfx card is a better choice.
Old March 25, 2010, 11:49 PM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
When it's not being used it goes into an low-power idle state, it produces very little heat.
Old March 26, 2010, 03:56 AM
cozmosland's Avatar
i havent done much reading into the on integreated gpu's but can they be used along side a proper gpu or would that be pointless and stupid.
Old March 26, 2010, 10:37 AM
Alongside in what way? You can't use it to improve 3D performance. As for using it to perhaps drive an extra monitor, I'm not sure if that's possible. Most motherboards with traditional integrated graphics will disable the onboard video when a video card is installed, but H55/H57 boards might work differently.
Old March 26, 2010, 10:42 AM
running a couple giga bards off the integrated while main gpu folds or something else.
Logitch X-540 5.1 - Pointless for music? Stix26 Audio 8 December 28, 2009 09:18 AM
Logitech X-540 5.1 Surround Sound System Rocco_360 Audio 7 March 26, 2009 12:54 PM
