-   -   EP45-UD3P +gskill 8500CL5D-4GBPK= problems (http://www.hardwarecanucks.com/forum/cpus-motherboards/27519-ep45-ud3p-gskill-8500cl5d-4gbpk-problems.html)
RMA'd January 7, 2010 02:04 PM
I can get 1 stick 2 work fine however 2 sticks just boots, totally unresponsive.I'm using slots 2,4 raised volts to 2.o and tried everything .I even broke down and called the so called techs at gskill and gigabyte they couldn't help either.Both sticks are good ,i RMA'd the board 3 times keep gettin bad boards.slot 1 i just get a black screen wont boot at all lol, so im using slot 2 with 1 stick for now .Any new ideas would be appreciated. Thanx
Q9400-2.67 @3.6GHZ__Arctic7cooler__ Giga-EP45-UD3P__gskill 2GB 1066__WDcavblk 620gb__750W Pc power&cool__XFX HD 4890 __ Lian-Li case K7B_ acer 23"1080p__ XP 32
Wurmer January 12, 2010 07:31 AM
If it's an option to you, one thing I would do is try another brand of memory with my rig. It might be a compatibility issue between your ram and mobo. Another thing that could be done is test your ram with memtest, it's a pretty darn good program and it has helped found quite a few bad memory module over time. On a side note, personally I have been having bad luck with Gskill. I know a lot of people like that brand and it seems to have a pretty good reputation. Nowadays, I am much more conservative with my choice of memory, for maximum compatibility I almost exclusively use Kingston. I like their HyperX series. Honestly, I doubt that you got 3 bad motherboard in a row that have the same defective memory slot. It's not impossible but that would be pretty surprising.
3.0charlie January 12, 2010 10:01 AM
If Gigabyte accepted the RMA, it means that there was indeed something wrong with all 3 boards, unless they sent back the same board 3 times.
Try raising the Vnb volts by 0.1V and make sure the sticks are running at the voltage spec.
If it boots, then run Memtest86+.
Sagath January 12, 2010 10:10 AM
Ahhh, good ole Gigabyte RMA. Gotta love them returning the same dead products. Happened to me too.
Solution? Dont buy Gigabyte. The ammount you've spent in shipping mailing 3 boards back you could have bought a new (non-GB) board!
