  #31 (permalink)
Old January 6, 2010, 05:29 PM
Snafu's Avatar
WARNING: OT again
the problem was that I have no printer driver install. Many software look at the printer driver.
Can you force install a printer, anything, to make it think a printer is there (control panel>printers and faxes>add printer). Should not matter which printer you choose. You just want it to think there is one ;)
BTW PS Elements 5.0 here on a p4 3.0c system opens a 4MB pic in about 5-10 seconds. No where near the "blink of an eye" speed but not bad.
Newest system: Intel E8400, Gigabyte EP35-DS3P, OCZ PC2-9200 Reapers, Seagate 3GB/s HDD, etc.
Others are kicking around the house.
  #32 (permalink)
Old January 6, 2010, 05:33 PM
MarkOne's Avatar
you get it , you only need a driver install
  #33 (permalink)
Old January 8, 2010, 09:11 PM
I would choose raid 0 harddrive if you on budget / if more to spare SSD. For photoshop editing, buy a good Dell monitor, 24" would be a good choice because you need accurate color reproduction. LOTS of memory is needed. I have 12 Gb for modeling and image editing.
  #34 (permalink)
Old January 12, 2010, 10:48 AM
Snafu's Avatar
Despite the "I want a new computer fast" statement, it turns out that it was a simple problem. Once that was solved there was no longer a desire for a new computer :(
I do want to say thanks to all for your input! Much appreciated.
  #35 (permalink)
Old January 26, 2010, 07:08 AM
you will need a SSD and a decent graphics card
system value misterd Off Topic 7 August 25, 2009 07:21 PM
Buying a used copy of Photoshop CS4 Zmanno999 O/S's, Drivers & General Software 7 July 4, 2009 12:11 PM
Under $2000 Gaming/Photoshop Rig Including Taxes logos New Builds 20 October 30, 2008 06:40 PM
Need help with new system fuffalo Overclocking, Tweaking and Benchmarking 15 April 17, 2008 07:47 PM
New System! :) Kandorf Troubleshooting 2 October 3, 2007 03:24 PM
