Old January 6, 2010, 03:55 AM
cozmosland's Avatar
dont feel bad, iv tried everything i can to get mine to unlock and it just doesnt want to. 0932apmw
grr
Old January 6, 2010, 08:13 PM
OH MAN! THANK YOU SO MUCH PARINEUM! I set my cpu voltage to 1.475, and BOOM! Works! Ran Prime95 for an hour now. Still no problems! :D
Old January 6, 2010, 08:23 PM
jcmaz's Avatar
Oh that's why my 720BE didn't unlock. I only used 1.3 volts. It booted to Window's but black screened. Btw, does Cool N Quiet have to be off?
-Plato
Old January 6, 2010, 09:56 PM
Perineum's Avatar
Make sure you have a Prime95 thread for each core running and then run for at least 8 hours.... I've had many overclocks fail in the 1 to 5 hour range.
Also, Folding@Home via a VMware seems to be very good for finding stability as well.
I haven't gone over 1.525 volts, so that's uncharted in my books but it wouldn't suprise me if you needed 1.500 or 1.525 to be stable overall. Again, you should be able to get around 3.8ghz at these voltages.
If you find that you OC and then one or more of the cores "disappear" then you need to up the voltage.
1.525 volts at 3.8ghz I can run 40+ hours of Orthos/prime95 no problem and then run F@H endlessly without problems.
I think it's safe....
I don't think so. I'd originally try with it off and get stable then turn it on and retest. I can't see it causing a problem. I do run the fan full speed however, as the temp sensors don't work anymore....
Btw, 550BE @ 3.8ghz is worth almost 6K while folding.... not bad.
Tags
550be , amd , asus m4a79t , phenom
AMD unlock phil3_66666 CPU's and Motherboards 5 November 17, 2009 06:46 PM
Phenom II X2 550BE (UNLOCKED) punk_zappa Overclocking, Tweaking and Benchmarking 75 August 29, 2009 11:45 PM
AMD Phenom X3 LooseCannon CPU's and Motherboards 6 April 24, 2008 11:22 AM
AMD Phenom Kappy CPU's and Motherboards 4 March 26, 2008 06:24 PM
AMD prepares its Phenom FX, Phenom X4 and Phenom X2 lineups Babrbarossa Press Releases & Tech News 1 May 4, 2007 07:38 AM
