Originally Posted by Lamb The things is that an higher-end processor is supposed to do better than lower end, it's not supposed to go the other way. |
In limited tests, yes, it can do better. You're still talking 2 core vs 4 for other apps. And it has a distinct clockspeed advantage at stock/turbo as well. These are not apple/apple comparisons. If you're going to cherry pick results, sure you can say the i5 6xx series is 'better' then the 920. However, if I'm going to cherry pick results, I can easily say the 920 is better. This is why we make apple/apple comparisons.
