Old September 28, 2007, 11:22 PM
BALISTX's Avatar
Default My Next Build.
As you all know I have decided to upgrade and jump camps from AMD to Intel. This project was going to be a $300 Overclocker but I have decided to put a bit more money into it.
Motherboard: Asus P5K-E/WIFI-AP - $171.72
Processor: Intel C2D E4500 - $156.00
Memory: Mushkin HP2 PC2-6400 DDR2-800 4-4-4-12 - $89.99 - bought
CPU Cooler: Arctic Freezer 7 - $21.47
Memory Cooler: OCZ Active Memory Cooler - $19.01
Optical Drive: LG 18X Dual Layer DVD±RW SATA - $32.40
I am unsure of the PSU. Let me know if there is a better for around the same price.
Power Supply: OCZ Stealth Xtreme 600 Watt - $68.65
Total: $559.24
Parts I already have:
Video Card: PowerColor Radeon X1600 XT 256MB GDDR3 PCI-E
Hard Drive: Seagate Barracuda 250GB 7200rpm SATAII
Case: Raidmax Xforce Mid Tower
Cooling: 2x120mm and 1x80mm Antec TriCool
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old September 29, 2007, 12:05 AM
sswilson's Avatar
Is the OCZ mem cooler being purchase mainly for form or function?
It sure looks cool (pun intended), but I haven't been able to see any verifiable improvement on mem OC with it installed vice no mem cooler installed.
To top it off, I've found that it doesn't always play nice in the sandbox with longer video cards (I had to remove one of the thumbscrews to allow for installation of my 1950 pro on the DQ6 board), and I'm sure that Patriote might have a few words to say about its electrical conductive properties......
If it's for looks then fine, it looks great!!!... if it's for function, you would probably be better served with one of the antec spot fans.
Old September 29, 2007, 12:23 AM
BALISTX's Avatar
I guess I don't really need it if I don't intend to overclock the RAM. My goal is to overclock the CPU to 3.6
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old September 29, 2007, 05:10 AM
Fallen Folder
I have a few of those psu's that I got through rma's on a couple of my older 420 powerstreams.
I use them to run my oc'ed quads on dedicated folding rigs so the rigs are pretty barebones ... they only have 1 hdd, a very lowend pci video card, 1 hdd, and a few fans.
They don't seem to have any problems suppling the juice to my quads which are running 3.0 - 3.3 ghz with <= 1.4V on each.
One has been running ~ 2 months 724.
Old September 29, 2007, 07:42 AM
BALISTX's Avatar
I'm only going to have one hard drive and the X1600 XT doesn't require a whole lot of power.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old September 29, 2007, 07:51 AM
CPU=Core 2 Q6600
Motherboard=Undecided leaning towards DS3L (DS3R if I do RAID)
RAM=PC26400 4GB
2nd harddrvie=160-200gb (might RAID with 1st hdd)
More of a wishlist than anything. once i get the go ahead AMD might have their quad's out (desktop ones) and we'll see what happens.
3800X2@2.2GHz--2gb PC3200--200Gb Maxtor SATA2--eVga 8800GTS 320mb--eVga nForce4 SLI mobo--Klipsch 4.1--Antec nine hundred case w/Vantec 120mm on side--Vista Premium 64bit
Join our Folding@Home team!
Old September 29, 2007, 09:10 AM
Patriote's Avatar
DON'T BUY THE OCZ RAM COOLER! It ain't well built at all. The fan will probably start to become noisy as hell in a month or 2 of utilization and you'll want to remove it because you can't support the noise anymore and also because the vibrations it produce are going to make you angry.... So you'll remove it and accidentally you are going to touch your 8800GTS with the bottom of the cooler, you'll short it and it'll be dead.
Seriously, the cooler might look good but it's just a piece junk.
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old September 29, 2007, 09:18 AM
Ditch the memory cooler as they aren't needed if you got good case ventilation and your memory doesn't run hot (it shouldn't).
Depending on how much overclocking you plan to do that AC Freezer may not be adequate enough to keep the chip cool.
I'd swap the LG optical for a Pioneer.
Powersupply should be fine.
Old September 29, 2007, 11:00 AM
BALISTX's Avatar
I take it this is an experience you had.
I'll save the money and ditch that cooler, maybe I add the $20 for another CPU HSF. Any recomendations?
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old September 29, 2007, 12:44 PM
BALISTX's Avatar
Depending if it fits I will probably get the Scythe Ninja Plus Rev. B - $35.73 at Direct Canada.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Build a new rig newmill CPU's and Motherboards 32 November 12, 2007 06:37 PM
First build. l0ck Troubleshooting 15 July 25, 2007 04:24 AM
New build -Yes it's fun... Il Duce CPU's and Motherboards 15 July 8, 2007 07:57 PM
New Build and soon to go buy neurobashing CPU's and Motherboards 10 June 20, 2007 09:23 AM
My first ever build, help me out paolo CPU's and Motherboards 31 June 9, 2007 04:04 AM
