Old September 28, 2007, 10:58 AM
Default The Beast is Toast
Hi Folks,
After installing a Swiftec MCW30 North Bridge Cooler and a Koolance VR-AS40 Vreg Cooler to my P5W DH-Deluxe, I had started board with xtx1900 and 1900 cf in place without rear molex(s) in place, shut down and properly connected molex(s) and now no POST.
Board led lights up, PSU operation verified by Digital VOM, QX6700 Status unknown.
I stripped machine down to a stick of ram, cooling pump, old pci vid card and a hard drive. Pulled battery and reset CMOS for 6 hours, still no joy.
I dont have a 775 board kicking around for processor verification,
Standing by for upgraded replacement board delivery with fingers crossed.
Any suggestions?:help: Other then buy AMD ?
Old September 28, 2007, 11:11 AM
sswilson's Avatar
Originally Posted by Shredder View Post
Hi Folks,
Ouch!!!!!!!!!
Other than trying the CPU on a different board, there's not much else you can do...............
Old September 28, 2007, 01:50 PM
Misoprostol
Guest
Posts: n/a
probably the mobo. CPUs don't generally die.
Old September 29, 2007, 12:50 PM
Default Hoping
Well I hope the cores are fine, Im gonna drop them into the BlitZ Board.
ASUSTeK Computer Inc.
To utilize the DDR2 ram I have.
Any words of wisdom on this board ?
I think Ill wait a bit before dabbling into the DDR3 board Blitz Extreme, I am still kind of hoping for the PCIe lanes to fully open at 16x2 in these DDR3 boards.
http://www.intel.com/products/chipse...ck_Diagram.jpg
Old October 4, 2007, 07:59 PM
Default Good News
I installed the new board, put the cpu into it,assembled the water cooling for the cpu and ran it in series with the Fusion Block. The Kentsfield is OK
Preliminary observations on the board...Core Temps are up 7 degrees from P5W DH Deluxe with 1 less water block. Looks like there is a few goodies on this board to play with.
Old October 5, 2007, 10:53 AM
Blitz has different power regulation than your old board, and thereby has less "droop", accounting for the slightly higher temps. P5W, unless modded, set 1.6v, get 1.52v...maybe...Blitz, set 1.6v, get 1.575v
DFI-STREET is toast sswilson Off Topic 12 February 12, 2007 07:43 PM
