Old September 28, 2007, 11:29 AM
sswilson's Avatar
Originally Posted by chibi_man View Post
interesting. Sadly i can find some Used 939Dual-SATA2 for fairly cheap, but who knows whats happened with them. the 939Dual-VSTA is still an option... i've read a bunch about it.. and so far it's just a fixed up version of the previous board. I'll have to look for a +3700. any details on why it's better?
Because it's based on the same core as their FX chips..... :)
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old September 28, 2007, 11:41 AM
chibi_man's Avatar
Ah.. thats a good reason to buy it :)
So which board in your opinion?
_____________________________________
If you can't beat it...
Old September 28, 2007, 11:53 AM
sswilson's Avatar
Let me do some searching for you this weekend.... I ran the crap out of a 3700+ for quite some time, and I'd hate to see one crippled by a less-than-stellar overclocking board. :)
For S939 OC boards, you really want a Nvidia chipset board. I'm thinking DFI or MSI if one can be found that does AGP.
Any preference on purchase location? (Newegg isn't going to do it for you as they won't ship to Canada........).
Old September 28, 2007, 02:31 PM
b1lk1's Avatar
Best possible S939 AGp board is the MSI K8N NEO2. OC'd like a monster. Avoid the DFI NF3 board like the plague. It was absolutely dreadful. Anything with the NF3 chipset should do well EXCEPT the DFI version.
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old September 28, 2007, 03:51 PM
JD JD is offline
Just a thought...
Why not get a X2 3800+? TigerDirect has those as OEM for about $60 I think. Might as well get a dual-core at this point in time.
Old September 28, 2007, 10:43 PM
BALISTX's Avatar
The Athlon64 3700+ is better for overclocking than the X2 3800.
Heatware
HWBOT
Old September 29, 2007, 12:01 AM
Amon's Avatar
And you'd be taking a very steep drop in clock frequency in terms of the K8 architecture. It can be seen as a step backwards, for what it's worth.
Old September 29, 2007, 07:20 AM
chibi_man's Avatar
Thanks for helping me do some searching, I appreciate it.
I have a buddy in the states. Hes attending a university in Tennessee. Since I go down there almost regularly it's not an issue to order from the states. So thats one really good thing.
I really want to keep my computer single core. I just find that a single core processor can perform better. It's all my own preference.
ASRock still has my favor... just can't decide which model I prefer. I will have to do some more research then to.
  #19 (permalink)
Old September 30, 2007, 08:59 AM
chibi_man's Avatar
Well, done some more research and I still like the 939Dual-VSTA board.
I found one problem with this board. my new case, i built it for a board sized 12" x 7.6" and the ASRock board is 12" x 9.6". So it looks like I have to modify my case if i build this. No big deal, it's worth the change.
If you have any other Board ideas please take into consideration:
DDR Dual Channel
AGP 8X
and try to keep it 12" x 7.6
and 939 is obvious.
  #20 (permalink)
Old September 30, 2007, 10:27 AM
Ok I found both boards. NEW! and in stock... now the decision... i'm leaning towards the 939Dual-VSTA.
Oh and I also found a new 3700 for 51.99$
what CPU are you upgrading from anyway?
3800X2@2.2GHz--2gb PC3200--200Gb Maxtor SATA2--eVga 8800GTS 320mb--eVga nForce4 SLI mobo--Klipsch 4.1--Antec nine hundred case w/Vantec 120mm on side--Vista Premium 64bit
Join our Folding@Home team!
