Old December 31, 2009, 01:44 PM
odis172's Avatar
Default Identify a rack!
Im trying to buy some rails for this rack i purchased recently, but I cant fine a model number anywhere! The guy said it is a "sun rack." Any suggestions for rails? I dont necessarily need them to slide out. This distance between the front and rear brackets is 30'' but i think i can flip them around to make the distance about 26''
The dimensions are:
85" approx in height
33.5'' length
23.5'' wide
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old December 31, 2009, 01:56 PM
Cptn Vortex's Avatar
Pretty much standard. The rails usually go with the specific case i.e. Antec cases use antec rails, chenbro/chenbro, you get the idea. Antec 26 Inch Sliding Side Rails (26 SIDERAILS) in Canada - Fast Shipping 1.866.800.8060 Those are 26-33".
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old December 31, 2009, 04:19 PM
odis172's Avatar
Oh okay thats much simpler then what i was expecting. Im pretty sure ill be using this case
NCIX.com - Buy Compucase RA455A00 EATX Server Case 4U 6X5.25 3X3.5 2X3.5INT Black - RA455A00 In Canada. but im having a heck of a time finding rails for it. It says its compatible with most ots rails. So does that mean the antec ones will work?
Old December 31, 2009, 11:10 PM
lcdguy's Avatar
your not the only one having trouble finding rails for compucase. Some rails may attached but won't have the right height. (there will be gaps between components.) For the best fit you need to use rails from the manufacturer so i would go for something from chenbro.
Small rack units? 3.0charlie Cases 5 September 5, 2008 05:31 PM
Weird question... looking for a rack cabinet djbon2112 Off Topic 7 July 28, 2008 08:25 PM
My new Lian-Li PC-V1000 + Mobile Rack r00tman Cases 11 August 27, 2007 07:28 PM
Danger Den Torture Rack Review Discussion Thread Misoprostol Cases 1 June 7, 2007 01:20 PM
