Old December 30, 2009, 02:22 PM
Default p57 vs p55?
whats the point of P57 chipset? I read some articles but couldn't figure it out.
Old December 30, 2009, 02:34 PM
MarkOne's Avatar
i tough Intel they remove the p57 of the roadmap
Old December 30, 2009, 02:59 PM
I though that was braidwood
Old December 30, 2009, 03:13 PM
I'm pretty sure P57 was indeed canceled.
Old December 30, 2009, 03:27 PM
Sagath's Avatar
p57 was the braidwood update to P55 iirc, it was canceled. The next update hasn't been announced but I would suspect it will be a USB3 and SATA6 chip, and that will probably include an updated chip for x58 with those features too.
Old December 30, 2009, 03:50 PM
JD JD is offline
Some boards already have USB3/SATA6 thanks to add-on controllers. So if one really wants one, you can get it already.
Old December 30, 2009, 04:31 PM
oh it has? Ok. Isnt there a new chipset coming out with the clarkdales? with an video out on the motherboard?
to above poster
add on controllers kinda suck, having usb and sata 3 on the chipset is much better.
Old December 30, 2009, 04:35 PM
JD JD is offline
to above poster
I know they do, and they eat up PCI-E lanes as well.
And the chipset you're thinking of is probably the H57.
Old December 30, 2009, 04:50 PM
Sagath's Avatar
Right, but those are like you said, Add-In chips, not built into the Southbridge or northbridge for 'native' support. Slight difference, but for Intel its a huge difference. Generally speaking when Intel makes it available in their chipsets that is when companies actually start producing said products with those features. SATA 1.5 is a perfect example of this around the P865 chipset, circa 2003, iirc. Add-in cards were around for nearly 8 months before Intel released it built into the chipset. Then once it was, Hard drive companies released SATA drives very shortly afterwards.
That is a totally separate technology called Moorestown, where Intel is moving a GPU on-die with the CPU. It will require its own PCH, which iirc is called Lincroft or Larcroft or something. Edit: Sorry, thats the handheld internet devices SOC intel is working on.
The other one with GPU+CPU was scrapped for the time being, it was called Larrabee
Old December 30, 2009, 04:59 PM
uh... dont think so. Im sure that the new 32nm i3 and i5 dual cores have a built in gpu.
DFI MI P55-T36 First Mini ITX P55 Motherboard FiXT Press Releases & Tech News 11 November 6, 2009 11:47 AM
EVGA P55 Mobo Lineup Revealed + P55 FTW Preview Comment Thread SKYMTL CPU's and Motherboards 11 August 22, 2009 10:31 PM
Intel to Scrap Braidwood Technology From P57 Series. FiXT Press Releases & Tech News 7 August 19, 2009 03:00 PM
Someone tell me what the P57 Intel chipset is? bojangles CPU's and Motherboards 1 April 12, 2009 01:26 PM
