Old September 27, 2007, 03:35 PM
Default Someone that knows about PSU's
I can get this Tagan TG 480-U01 from my friend for 30.. retail is 60
It has 28A on the 12V+. would it be any good for my system
Where is my SIG..?
My Specs:
Intel E2160 @3.6Ghz / Q6600 GO....Real Soon
Coolermaster GeminII with 2 x 12V 120mm 125CFM Fans
DFI Infinity P965-s Dark
EVGA 8800 GTS 320mb
2 x 1024 Memory 1066Mhz
2 x 250 WD SATA II
Antec 900 Case with 3 x 120 mm Fans 1 x 200mm Fan
Old September 27, 2007, 07:10 PM
Amon's Avatar
You'll want a 600-watt unit unless that Tagan can run 110% load 24/7...
I know not much about power supplies, but it would seem like common sense avoid that sort of overload scenario.
Old October 15, 2007, 03:34 PM
Theblackmages's Avatar
yeah thats a bit too close. I'd get something Mushkin or OCZ with quad +12v rails. The gamexstream is pretty cheap if i remember correctly
Old October 15, 2007, 03:53 PM
Posts: n/a
It would *probably* be fine, but why tempt the gods?
Old October 15, 2007, 04:51 PM
b1lk1's Avatar
With your current CPU, OK. With a Quad, no no no no no no no no no no no no no no no no no no no no no..........
DAILY: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 270 2GB/128GB SSD+750GB HDD+2TB HDD
Old October 15, 2007, 07:23 PM
turtletrax's Avatar
I am really loving the Silverstone ST75ZF. I am running dual DDC-2's, OC'ed quad, 8800GTX, 3 HHD, 4 Sticks DDR2, DVD-RW, 2 PCI cards, a power thirsty X38, and 8 fans without a hiccup.
Best PSU I have ever run, and I payed $169 for it on NCIX
"It's time to kick gum, and chew ass. And I'm all out of gum."
Dick Kickem
Single vs Multi rail PSU's durdy Power Supplies 1 December 30, 2007 09:16 AM
