Old December 28, 2009, 08:45 PM
Default Asus P7P55D SATA problems
Hi all,
I wasn't quite sure if this fell more under hard drives or motherboard, but it seems like a SATA problem.While trying to repartition one of my hard disks for a clean Windows 7 install with G-parted, I ran into an odd problem. When both independent drives are plugged into the P55 SATA connectors, neither of the drives shows up. However if I plug one of the drives into the "extra" Jmicron SATA port, the other drive shows up. To compound the problem, if both drives are plugged into the P55 connectors, they show up in the BIOS. I'm wondering what could be the root of this problem, and would it be easily fixable?
Cheers!
Wolf
Update: I used a program to wipe the drive clean, and managed to install 7. However, the drive that I backed up my files to still refuses to show.
Antec 900
Intel Core i5 @ 2.66GHz
Asus P7P55D motherboard
EVGA 9800 GTX+ Superclocked
4GB of Patriot Viper II DDR3 RAM
2X320 GB Western Digital @ 7200 RPM
Plextor DVD +/- RW
Corsair TX 750 W power supply
Windows 7-64
Old December 30, 2009, 12:36 PM
Fixed the problem. Turns out it wasn't a problem with the motherboard SATA ports. All I had to do was go into the Windows disk management utility and assign a letter to the drive.
Antec 900
Plextor DVD +/- RW
Windows 7-64
ASUS P7P55D Pro & 8pin EATX12 with cap Logger CPU's and Motherboards 3 January 2, 2010 02:18 PM
ASUS Introduces P7P55D Series Hybrid Motherboards FiXT Press Releases & Tech News 0 September 10, 2009 10:21 AM
ASUS P7P55D Deluxe Motherboard Preview Comment Thread SKYMTL CPU's and Motherboards 14 August 26, 2009 03:11 PM
Asus P5Q Deluxe SATA problems rvs1111 Troubleshooting 5 September 18, 2008 01:39 PM
