Old December 28, 2009, 02:41 PM
kendallcschm's Avatar
Default Bottle Necks?
can a video card prevent overclocking of a CPU??
Old December 28, 2009, 03:13 PM
Prevent overclocking? I haven't seen that. Although it is possible that adding a second video card can put enough stress on the northbridge to reduce overclocking potential. Generally when we talk about bottlenecking, we're referring to the phenomenon of one particular component in a system being underpowered and causing the rest of the system to perform below its potential.
Old December 28, 2009, 04:28 PM
belgolas's Avatar
But when they mean by bottleneck is usually less than a couple % slower and usually not a massive bottleneck like some people try to make them.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old December 28, 2009, 06:29 PM
bojangles's Avatar
Yup, what 2 and 3 said.
Old December 28, 2009, 07:12 PM
thanks.. i was just curious because my friend was talking about a more powerful GPU making it easier to overclock.. i guess that its a false statement thanks for the info
Old December 28, 2009, 08:13 PM
The bottleneck can be very large depending on the application and on the specific hardware in question.
No, that's complete BS.
Old January 26, 2010, 07:09 AM
the motherboard will be the most limiting factor of overclocking your cpu...and cooling ofcourse......
Old January 26, 2010, 02:44 PM
Perineum's Avatar
There ARE times where the onboard video has held some motherboards back from overclocking well. By adding a video card into the PCIE slot you can then get a greater overclock out of the CPU.
However, if you originally added a GTX260 in the slot you're not going to get a better overclock by later adding a GTX280.
Hope that makes sense.
Old January 26, 2010, 03:16 PM
Im not 100% but most cores these day Will max out a Mobos FSB, If set proper.
As for GPU causing a lower overclock... Smack your friend with a BAT.
[FS] bottle's FS thread bottle Buy/Sell & Trade 18 January 30, 2010 03:32 PM
can I use an old plastic bottle for a res? Shadowmeph Water Cooling 5 May 3, 2009 06:41 PM
